Sound and air come through the door. Wick?
08.05.2020 20:21 # 1
gkhn92
Good evening everyone.
I am a 2004 1.6 Xt Premium 307 user. My car gets a lot of sound and air through the right front and rear door. Especially when it rains, the sound of the tires sounds like the door is open. However, water ingress etc. Absolutely not. When I showed the upholsterer, the problem was suppositories. Could you have anything but wick? I don't want to waste time, doors closing sounds etc. are full enough. However, the rovings never changed. I am the first owner of the original rovings. No one else used it.
Thank you in advance for your help.
08.05.2020 20:21 # 2
OguzhanKucuk61
It is a piece that has lost its feature in time. You asked 2 different masters, you also know the vehicle before. I do not think of any other reason, frankly :) get well soon :)
08.05.2020 20:21 # 3
gkhn92
[QUOTE = OguzhanKucuk61] A piece that has lost its feature in time due to its structure. You asked 2 different masters, you also know the vehicle before. I do not think of any other reason for me, frankly :) get past [/ QUOTE]
Thank you Oğuzhan Bey :)
A rupture in suppositories etc. I approach with suspicion because I have not seen. He said flattened, the masters said I would ask before changing it :)
08.05.2020 20:21 # 4
childrenofgrave
I had a similar problem in my old vehicle. Insulation was very bad. As a result of the research, I found a solution like this: You will lubricate the serum hose, which you can find from medicalists or pharmacies, make a few holes in the wick and pass it through the wick. It works. There are production videos from Youtube. You can watch and try.
08.05.2020 20:21 # 5
OguzhanKucuk61
You're welcome, teacher. Although it is not torn, it may not be able to fulfill its duties since it is old.
08.05.2020 20:21 # 6
yigit_dark
I recommend silicone spray for door seals. It protects wickes and softens and prolongs its life. I apply it to my vehicle at regular intervals. There are many benefits in glasses too, it gets dusty over time and it gets harder to open and close.
