Sound after steering change (resolved)
08.05.2020 17:06 # 1
Alicilik
Hello guys, I asked the service for 206+ from the leather steering wheel in the envy. The steering wheel in the RCZs is gray coated. I bought it for 260TL. Both original and leather. If I want to make leather in that way, they will not make it lower than 100tl and the stitches will thicken in a time that will create a problem in time. How to disassemble the airbag How to remove the cables I watched carefully. And I changed the ring. I closed the airbag fln. Of course, the battery terminal is removed while doing these. Then I started to turn the vehicle right and left. The first thing I noticed was that the steering wheel's point of view changed. This bagel was looking a little higher. It is not a problem, on the contrary, it was even good. Then I started to turn left and right. The steering has noticeably hardened. It was as if there was no hydraulic at all. I tightened the screw in its setting, though it had nothing to do with it but I couldn't make sense. Over time, the steering wheel got softer, I understood this when I got into the car for a long time and then got on. That problem was solved, and then there were cracks from inside while turning it to and fro. At first, I said from the cables, but when I looked at it, it sounded like it was coming from the com2000. Again I removed the upper and lower cover and looked. I carefully turned the com 2000 on the side of the shaft, there is a black ledge holding the cables leading into the steering. That ledge turns with the steering wheel. Part of this piece came out and was sitting with the hand pushing, but the tooth did not hold properly and came back when I left it. Just below it is the ring of the cables going to the steering wheel, which rotates together and the sound comes from that part. So I put the piece between the steering wheel and that black box, and it squeezed that piece, but I can't say the sound was cut off to some extent. The sides of this box I'm talking about are ring-shaped and a small white piece goes between these rings and this piece plays the black box as it turns left and right. This sound problem is felt when it is silent. Does anyone have any idea what could be the problem? 2013-01-07 18:04:25
08.05.2020 17:06 # 2
Alicilik
guncel
08.05.2020 17:06 # 3
Alicilik
update
08.05.2020 17:06 # 4
ERSOY-06
hello brother.
current
respect
08.05.2020 17:06 # 5
ufuk91
teacher, you told me so complicated (though I think you did your best, but the situation is complicated) I couldn't even visualize the situation in my head, I wish you opened 1 2 photos
08.05.2020 17:06 # 6
feline
get a current from me
08.05.2020 17:06 # 7
Alicilik
The exam period has begun, I could not even take care of the car.
As soon as I will look at that sound again - I will continue with the remaining sound insulation (trunk-roof-floor) - there is a problem in the speaker of the right front door, I will look at it off off
08.05.2020 17:06 # 8
GiTaRRa
Did you try to move the steering wheel with the poles removed? In other words, how did you force or force the steering wheel when the vehicle was not running? You are really very complicated, let's just laugh at the beginning ..
08.05.2020 17:06 # 9
Alicilik
The case is as follows:
In the beginning, I disassembled the pole, so that the airbag and the horn do not cause any problems.
I disassembled the airbag. The horn had a chassis, I dismantled it, and I had only a single bagel. To unscrew it, I unscrew it in the middle screw.
Of course, the bagel did not come out so easily. I struggled a little and pulled hard towards myself.
Then I put on the new wheel. I made connections, I sat on the airbag. I put on the pole and started the car. I turn it like a plastic bits are hanging somewhere. I examined it a little. com2000 has a bump in the front. It's coming right under the wheel. That piece is connected to the steering wheel with two legs, the airbag and horn cables go between those feet. This piece is like a blower.
The cables that go to the ring come out of a thin ring. this ring is in white and the bellow-like part that I mentioned is rotating under the steering wheel again. These two pieces are moving together, and there is no sound from them.
08.05.2020 17:06 # 10
GiTaRRa
Are you sure you fit the bagel right? Look at the bottom of the bagel with your hand.
08.05.2020 17:06 # 11
ERSOY-06
Brother, do not worry about them, you can do it anyhow, you can handle it, these problems are child's play for you, my brother.
I wish you success in exams.
08.05.2020 17:06 # 12
Alicilik
[QUOTE = ERSOY-06] my brother, don't worry about it, you can do it with intensity in your exams anyway, these problems are child's play for you, my brother.
I wish you success in the exams. br>
Thank you brother. Let's look at the shelf for now. I will examine in detail
08.05.2020 17:06 # 13
spearo
There is a jerk that threw the ali signal to the right and left.
08.05.2020 17:06 # 14
Alicilik
[QUOTE = spearo] there is a jerk that throws the ali signal to the right and left, you couldn't put it on properly.
08.05.2020 17:06 # 15
spearo
If you wait for a short time, I will send you the pictures of the steering wheel disassemble plug guide.
08.05.2020 17:06 # 16
Alicilik
[QUOTE = spearo] If you wait less, I will send you the pictures of the steering wheel remove plug guide. [/ QUOTE]
I was careful while removing the brother. There was a mark fln on the screw. I wore everything old but there is a problem somewhere. I couldn't solve it.
There is no problem in signal but it works properly.
08.05.2020 17:06 # 17
Alicilik
Friends, the problem has been solved! Now I became even more mindful, I will not dismantle the car anywhere. As I wrote at the beginning of the subject, I changed the steering wheel. Then a contraction and voices began to come. There was a crack in the way as the steering wheel turned. As I was leaving the parking lot today, I turned the steering wheel completely and it sounded scarce. When I got back, the car started to turn the steering wheel to the other side, sounds like I was crushing something with the wheel. Thanks a friend (in service) said industry go. They produced nearly 550 numbers. Only com2000 will change its winding is broken. However, there was no problem in the arms. I also brought the original, then the problem may arise, said the master. The man said 275 brother, I was almost getting it later on, I thought of this brand event. I said that now, these pejoes are emphasized by the master. I asked the brand Valeo said. My head soup was thoroughly. I got out of here, give your hand to the star auto dating industryI asked two places in the industry. By the way, one of the publishers recommended a pejo service, it was a place I went before. If it wasn't there anymore, I would buy a piece to get out of here. I went to the service, I said to the master, I was bored. I said that it was snow here in a row. The master made 130tl with the bargain. but now it happened. Both the airbag and the horn improved. and the steering has softened. It was officially without hydraulic before. Now I'm turning one finger. We closed the day with 130TL - but we experienced it. We solved the problem before a blessing account grows from a thousand advice. It is not, the concentration that I have already collected while working in the finals at school is dissipating with these, I feel more bored tonight, there is no sleep again.
08.05.2020 17:06 # 18
Serkan
Get well, Ali means you shouldn't be too tired :)
08.05.2020 17:06 # 19
Alicilik
[QUOTE = Serco05] Get well, Ali, I mean I shouldn't be too tired :)
Thank you brother,
They said everywhere I went pejo service car find a master deal they say so thousand.
Worse than that, I have a 2004 fiesta, my uncle is dealing with him. I'm amazed that it doesn't get into the car. What did I try to do now: D I will get the job done by the master. Reviews
08.05.2020 17:06 # 20
serkan719
so what made that sound. kolmu com2000
Page : / 2
