sound
08.05.2020 18:12 # 1
Exdamega
MY PROBLEM 206+ THE SOUND DOES NOT COME FROM THE REAR SPEAKERS IN MY VEHICLE I CAN'T MAKE ME HAPPY IF YOU HELP ME THE SECTION IN YOQSA ....
08.05.2020 18:12 # 2
Alicilik
Have you installed a rear speaker because most models do not have a rear speaker. If you attached the rear speaker to the original tape, you need to connect with pp2000 or diagbox from the service and turn on the fader setting from the radio.
08.05.2020 18:12 # 3
Exdamega
yes i have it myself but i know about what you call pp2000 or diagbox yoq let them investigate them thanks for your help .......
08.05.2020 18:12 # 4
barishrocker
I have never used 206 but normally if the fader is taken from the fader and balance settings, it may be necessary to adjust it. fader and balance should be 0 probably ..
08.05.2020 18:12 # 5
Alicilik
[QUOTE = barishrocker] 206 I have never used but normally it may be necessary to adjust it if the fader is taken from the fader and balance settings to the front. fader and balance should be 0 probably .. [/ QUOTE]
On vehicles without rear speakers, the fader setting is turned off. There is only balance adjustment. So the rear speaker is not working. It sounds when you activate the fader from the radio settings. It turns out in the menu fader setting
