sony tape socket
08.05.2020 17:37 # 1
impact
Friends I have set the sony cdx-a250 model tape to think of plugging it to get more quality sound. however, as seen in the picture 1 and 2, I think the tape cable was cut off and I think the cable in the 3rd picture should be.
1.What's the name of this cable?
2. If we find this cable, will it be directly connected to the original socket of the car? Since my car is outside the city, I can not look it ..
iMPACT 2013-05-22 19:49:23
08.05.2020 17:37 # 2
Alicilik
My teacher is called ISO socket. If you say for Sony, there is fln in the tapes. I bought it for pioneer, the cables are the same color, before I put the macaron on it and solder it, heat it and make it original.
There are ready-made ones, but the socket on the tape is not very strong, so I combined it myself.
I have no idea about ready quality
http://www.ebay.com/itm/sony-ıso-adapter-cdx-gt24-cdx-gt25-gt29-cdx-gt33u-gt35u-/260794522197?pt=kabel_stecker&hash=item3cb8909a55
This is the type I took
http://www.merterelektronik.com/index.php?do=catalog/product&pid=2482
08.05.2020 17:37 # 3
impact
Well, the answer is from the person I was waiting for, brother, thank you.
08.05.2020 17:37 # 4
Alicilik
[QUOTE = impact] Well, the answer from the person I expected is thank you bro, is it not that this socket is directly connected to the original socket without cutting it out [/ QUOTE]
You're welcome.
The socket of the vehicle is ISO male. The outputs of the tape must also have ISO threads. A piece that will transfer the cable outlets of your tape to ISO. As I said, it happens in accessories selling audio systems. I also entered a shop that wrote a random pioneer. I bought it. If you switch from the original tape to this tape, you will also receive an ISO converter for Antenna.
08.05.2020 17:37 # 5
impact
[QUOTE = Receiveness] [QUOTE = impact] Well, the answer from the person I expected is thank you bro, is it not the direct connection of this socket without cutting it to the original socket [/ QUOTE]
You're welcome.
You're the bomb :)
good you said the antenna business ..
I think they will need a tape frame, I looked 40 lira or something ..
08.05.2020 17:37 # 6
Alicilik
[QUOTE = Impact]
You're the bomb :)
The antenna and that socket are important. The first time I bought the tape, I got the original (digicom) socket and that piece of antenna came out. Then, when the tape was leaked, I took a look at the end of the socket, there was no antenna part, I went to the industry while going on the road. When I went home, I threw a nice macaron and soldered it.
As I said, it is sold with a socket on both sides, but since I suspect the health of the socket of the tape part, it was useful to use the original.
I remember that Mahmut took the brother (tellotello) from the frame. I couldn't remember the price going on in the pieces
08.05.2020 17:37 # 7
impact
I can solder like you said but I couldn't be sure about the cable colors of some products. The car is in the cottage because I want to finish the work this weekend. If I can handle it in Izmir .. Let me see the flea market tomorrow.
08.05.2020 17:37 # 8
Alicilik
[QUOTE = impact] I can solder like you said, but I looked at the net. the car is in the summer because I want to finish the work this weekend.
Colors are more or less evident in each model. The socket with power cables is easy to handle, the cables are thicker and the colors are obvious. If the speaker cables get mixed up, take the solder with you and try it there.
Or, if possible, connect the tape to 12v (if you have a modem, modems usually work with 12v 1A transformer) and plug in a speaker.
08.05.2020 17:37 # 9
impact
[QUOTE = Buying] [QUOTE = impact] I can solder like you said but I couldn't be sure about the cable colors of some products. the car is in the summer because I want to finish the work this weekend.
we will do the worst as it is now ..
