Sony Mex -Bt2600
08.05.2020 14:00 # 1
I am using sony mex bt 2600 model cd player in my friends vehicle. My problem is I memorize these radio channels. There is no problem when the vehicle is running. When I turn off the ignition and restart the vehicle, it is deleted to all the memory channels and the tape is reset. Likewise, when I turn on and turn off the tape while listening to the cd, it returns to the beginning of the cd. does not continue from the song I stayed. I looked at all its settings but I couldn't find anything. If there are friends using this tape, can they help ..
08.05.2020 14:00 # 2
This is about electricity rather than tape. Does the tape work with the ignition off?
08.05.2020 14:00 # 3
No, it doesn't work when the ignition is off.
08.05.2020 14:00 # 4
[QUOTE = MaSHrAbA] yo no it doesn't work when the contact is closed .. [/ QUOTE]
If you connect the trigger of the tape straight, the problem will be gone. It is the best for your product to work when the ignition is off.
08.05.2020 14:00 # 5
I brought the tape from abroad. socket connection was made. What is the event that you call triggering 205 gti .. I can describe it to the electronic electronics here ..
08.05.2020 14:00 # 6
There is nothing to describe, brother, you are the one who understands this request, it is not difficult to get to the master.
08.05.2020 14:00 # 7
In other words, you will say that the tape works without opening the contact.
08.05.2020 14:00 # 8
ok thanks guys
08.05.2020 14:00 # 9
sinan-s
Electrician takes care of
08.05.2020 14:00 # 10
elenor
If the memory is erased each time the tape is turned off, the memory battery in it may have run out. Also known as the Backup battery, this memory is normally retained by the internal battery and does not need to be recalled. The battery may need to be replaced.
08.05.2020 14:00 # 11
I'm hard on the memory battery, the electrician who will make a flat connection will end ...
08.05.2020 14:00 # 12
savi_206
or there is a problem with the insurance of the line coming to the tape ...
