Some questions about my new car 206 ...
08.05.2020 19:53 # 1
horoz28
Friends, good forums, good holidays first.
I became a member of the forum by purchasing 2006 model xdesing 206 1.4.
There is a varnish on the roof of my car, it looks like a fading but it is a varnish. I don't want to paint what you suggest the solution is because it is the original tool. Can I polish the cake polish or varnish?
In addition, the car makes a sound like vuuuuuu when pressing the throttle in all gears. It only happens when stepping on the gas like a wolf howl.
thanks.
08.05.2020 19:53 # 2
First of all, welcome to our wish. Good luck to you now. let me start with the first problem
Unfortunately, 1-varnish throwing does not come out with a polish. you will either have full paint or have foil covered.
2-First of all, let me ask about this. If it is diesel, it looks like turbo sound and pressure pad, if it is gasoline, just like pad.
08.05.2020 19:53 # 3
horoz28
Thanks for the answer. I do not want to paint the car foil came to my mind, it is enough if I make the red black black foil ceiling. But in a familiar, this paint fading is not sunburn, it can only be thrown in varnish, he said.
When my car is running a gasoline vehicle or not when I go to the bus, only when I give the gas does it sound when my foot is in the gas. yesterday the vehicle was picked up and the starter engine sound abnormal engine sound abnormal left rear suspension grip weak rod adjustment required front brake pads control required says everything else is normal Could it be one of these items
08.05.2020 19:53 # 4
horoz28
http://hizliresim.com/vy8d1j
http://hizliresim.com/nr9n3b
http://hizliresim.com/v4a9v is
I added the pictures for the ceiling.
08.05.2020 19:53 # 5
You're welcome. paint fading is corrected with a beautiful paste polish. I thought he was throwing varnish. don't think of varnishing. The pastry does the job well. As far as I understand, I think this sound comes when the car stops. If the starter engine makes this sound and distributes the bearing or something, get the dynamo as soon as possible in an auto electrician.
08.05.2020 19:53 # 6
horoz28
Let's see my teacher, I'll stop by industry tomorrow
08.05.2020 19:53 # 7
Unfortunately, I would recommend you to have a coating from the beginning.
08.05.2020 19:53 # 8
horoz28
As if the paint is in place, if my teacher does not fade, if the varnish is scraped and only the varnish is thrown, will the situation improve or will my coating and paint be the only remedy?
08.05.2020 19:53 # 9
There is no other remedy for paint or coating like your grandpa.
