Some questions about 2005 307 XT Automatic
08.05.2020 17:30 # 1
MertMurat
Hello friends I just bought my car 2005 model 307 xt automatic
my car has been put into service at 112 thousand
90 thousand
lpg has been installed at 100 000
It has been 10 months
When I first picked up the vehicle when driving with D on a steep hill, when I suddenly stopped with the brake, the vehicle had 1 to N & nbsp; it was getting and passing to D again, the gearbox took 5.5 liters of oil when I changed the oil.
, but the old oil was like a bitumen. and its consistency is even more liquid, so its consistency is close to water.
the service tells me this car has never changed the oil
use 5 thousand km again let us change. really & nbsp; Voted oil did not do it after the change, but I said that if it does, I got bored.
& nbsp;
I have no knowledge of what this type of vehicle needs to be maintained.
& nbsp;
08.05.2020 17:30 # 2
MertMurat
I forgot to write Tool 1.6
08.05.2020 17:30 # 3
Your masters made accurate comments. I think trust them. You can not use any tool if you think what it does. You never know if this will happen. I don't think so, you will revise it if it happens.
08.05.2020 17:30 # 4
pierson
my car is also 2002 model xr auto 206 ... i don't know what gear oil is ... more precisely i don't know much about the car ... i always go from D in general ... of them are blinking ... this may be the cause ... There is no such problem at all in D ... when should I change the gearbox oil ... how much does it change ... how can I understand the change time ...
08.05.2020 17:30 # 5
[QUOTE = pierson] my car is also 2002 model xr auto 206 ... I don't know what gear oil is ... more precisely I don't know much about the car ... I always go from D to general ... but sometimes when I throw it 2 or 3 accidentally S and snowflake symbols are flashing in the gear position ... this may be the cause ... D is never such a problem ... when should I change the gearbox oil ... how much does it change ... how can I understand the change time ... < br> [/ QUOTE]
It is recommended that you change it every 30 thousand kilometers.
08.05.2020 17:30 # 6
MertMurat
I changed the oil a second time. All the problems in my vehicle disappeared.
Thanks
