|   | Some of the numbers in the KM counter are not read |
| 08.05.2020 21:13 | # 1 |
|  kaan206 | |
|  Could it explain what kind of a path would work if any such secret is living? Thanks  | |
| 08.05.2020 21:13 | # 2 |
|  sonerkyl | |
the same problem that resulted from that film.  | |
| 08.05.2020 21:13 | # 3 |
|  kaan206 | |
Thank you brother and the indicator will be super if you send the servo motor link   The temperature and the oil indicators are dead, the miserable ones have changed.  | |
| 08.05.2020 21:13 | # 4 |
[QUOTE = sonerkyl] exactly the problem that stems from the movie.   Can we make this film change, do we need soldering etc.?  | |
| 08.05.2020 21:13 | # 5 |
|  sonerkyl | |
[QUOTE = kaan206] my brother thanks and the indicator will be super if you throw the servo motor link   The temperature and the oil indicators are dead, the miserable ones have changed. [/ QUOTE]  unfortunately, my brother servo motor is sold on ebay or something I have not seen, but it is in the hands of some auto electronics.  | |
| 08.05.2020 21:13 | # 6 |
|  sonerkyl | |
[QUOTE = littlenikksay] [QUOTE = sonerkyl] the same problem that stems from the movie.   Can we make this film change, do we need soldering etc.? [/ QUOTE]  Unfortunately, I do not have much information, teacher, I need to do some research.  | |
| 08.05.2020 21:13 | # 7 |
|  kaan206 | |
Does some figures in km meter faint cause trouble in inspection?
| 08.05.2020 21:13 | # 8 |
|  kaan206 | |
friends temperature and oil temperature indicator sometimes work sometimes stay always at the bottom and also some of the figures in km meter do not appear.   Isn't there a problem before?   Can an auto electrician do? Do you have a ribbon or servo motor in your hand?   I went to an auto electrician just replaced the bulbs   I explained other problems, he couldn't say anything, I guess he doesn't understand much.   Is there any place to recommend in Istanbul  | |
| 08.05.2020 21:13 | # 9 |
|  sonerkyl | |
[QUOTE = kaan206] friends heat and oil temperature indicator sometimes work sometimes stay at the bottom and also some of the figures in km counter are not.   Isn't there a problem before?   Can an auto electrician do? Do you have a ribbon or servo motor in your hand?   I went to an auto electrician just replaced the bulbs   I explained other problems, he couldn't say anything, I guess he doesn't understand much.   Is there any place to recommend in Istanbul [/ QUOTE]  A good auto electrician who knows his job, ie peugeot, does all the problems you have. unfortunately I cannot help with the master.  | |
