(Solved) Starting, Vehicle Doesn't Start.
08.02.2022 12:10 # 1
Yasin57
Hello friends,
Recently, the vehicle started to stall, I changed the oil and filters because maintenance came, but today I got into the car, I pressed the starter, the vehicle did not start, but the vehicle does not start. Many people I know said it was caused by the coil.
Solved: There was a problem with the gas pump, we changed it and it was fixed. (He hit him on the head a few times before he changed it, and it worked on gas.)
08.02.2022 16:10 # 2
talip206
Even if it is from the coil, it works by stalling.
Either the fuel pump has blown or the fuses related to the engine section have blown.
08.02.2022 23:11 # 3
benkaan
There is a fault in the Martian dynamo, either the coal is finished or there is a solenoid fault in the Mars dibamo
2. If it is a reason, if you have changed the fuel filter, if the aftermarket has been used, as soon as the fuel filter blows up
08.02.2022 23:55 # 4
x571
hit the starter a few times sweetly with something like a hammer, let's see if it works
12.02.2022 16:53 # 5
gepi usta
footnote : if this problem occurs in diesel , the diesel pressure sensor will change .
