(Solved) Partner wiper problem?
08.05.2020 18:48 # 1
gkhn08
Hello friends,
I have a problem in my car, which is the last day, I have a problem. It stops .. What is the problem I can solve? or how much will it cost me?
I would like to thank everyone who gave an opinion that already answered ... gkhn08 2014-10-02 00:52:46
08.05.2020 18:48 # 2
peugeotefe
If your vehicle is a middle body partner, your wiper motor is out of order.
Piece price: 150 TL
08.05.2020 18:48 # 3
serdaralisan
look at the water before it runs out, then it is short-circuited and running fast and it is stuck in the engine.
08.05.2020 18:48 # 4
gkhn08
Thank you for the answers, let me tell you, neither the engine is burnt nor the water has escaped into it. I cleaned the pad using the sprays, I wiped it, there was no oil left, I lubricated it with the machine oil and it did not lubricate the coil and the coal parts. I put grease into the mechanism and it worked without any problems. It would be, but after I told my brother in another forum like this, I had something to lose and I removed it and did it 0 expense :) it was solid in the coals it was not finished :) Regards ...
08.05.2020 18:48 # 5
gkhn08
pictures in these ...
gkhn08 2014-10-02 00:49:35
08.05.2020 18:48 # 6
gkhn08
May Allah not drop it in the hands of the masters, they will repair the part they removed and flash it on someone else ...
The solution of the malfunction I have described is as I wrote above.
Respects...
08.05.2020 18:48 # 7
pusutr
Health to your hand.
