SOLVED /// Left windshield opening control problem ..
08.05.2020 20:14 # 1
Peugeot35
Guys, today I downloaded the driver glass, then I wanted to close it.
When programming the glass for synchronization, when you hold it for three or five seconds above, it gives a click sound or when the glass clicks up, it comes back. I leave it before I hear it, so I keep the window closed.
As a solution: I removed the control, I cleaned the card inside with cologne first, the same problem, I removed it again.
Is there such a problem passing through? Is it the solution controller or the control brain? obviously I suspect the brain, if you say why it raises it until it clicks, clicks cut it in half, and in a super mass, that glass does not move, all other windows are closing
do you think ...?
PROBLEM IS SOLVED....
This tactic solves the problem if anybody is having the problem I mentioned. (permanently)
I went to the authorized service, considering the problem may be from the brain of the engine, if there is an amount of 700 TL of expenses. It
may also be from kiriko because the glass is closed when it bends up, said he sent it to the glass shop, he told me the situation looked at the room, the wicks are squeezing the glass, the sensor is coming back, said the silicone spray, the glass started to come straight into the wick and the problem was fixed.
Our windows mean that the sensors were sensored, when the glass was lifted, if there was a finger jam, it would detect the sensor and lower the glass back. Wow, look at peugeot :) the glass wick is squeezing the glass. Keep in mind, there is a glass wick picture on the 12 tl I bought in silicone spray painters.
He said something about workmanship, I shook 10 TL, God blessed me from a big expense and trouble.
Peugeot35 2017-03-10 20:53:41
08.05.2020 20:14 # 2
BLACK LION
I removed and cleaned so much that it doesn't end with counting. It doesn't work, it doesn't work from air, water, dust. At first, not bad, then again, stiffness is still a distortion. Remove the battery and reset the car. Try this operation again. Press and hold the key for 10 seconds. close and 10sec. wait. It will be corrected if it clicks on and off automatically. It is improved if it is opening and closing with one touch. If not, now a new one has become a must, although it clears back. Even the mirror control is not gone anymore. I will buy a new one.
BLACK LION 2017-03-09 12:45:30
08.05.2020 20:14 # 3
pepecura
buy a new side industry around 90 original 110 TL
08.05.2020 20:14 # 4
Peugeot35
[QUOTE = BLACK LION] I removed and cleaned so much that it doesn't end with counting. It doesn't work, it doesn't work from air, water, dust. At first, not bad, then again, stiffness is still a distortion. Remove the battery and reset the car. Try this operation again. Press and hold the key for 10 seconds. close and 10sec. wait. It will be corrected if it clicks on and off automatically. It is improved if it is opening and closing with one touch. If not, now a new one has become a must, although it clears back. Even the mirror control is not gone anymore. I will buy a new one.
I did not reset. If the problem is in the remote, we will have nothing to do but if it is not, then the control will explode in my hand :)
08.05.2020 20:14 # 5
kaanbey34
My problem is the window closing problem with the remote control. When the rope spool of the left front door glass broke, we went to the repair, the reel changed, the single button changed because the claw of the on / off button was broken. When we said that the window started to open and close normally, it started to open back when we closed the window, it closes completely, the click opens, and as a result of long pressing with the remote control, I saw that the glass was opened halfway. A problem caused by master software, the brain remains unstable or something absurd. When I went to have it connected to the computer, they said that the malfunction did not have anything to do with the software, the malfunction of the glass motor. If there are users who encounter such a malfunction, I would be glad if you can help. So from the engine? Is it from compression of suppositories? Is the control malfunction?
08.05.2020 20:14 # 6
my teacher, this problem probably seems to be related to the workmanship of psa group vehicles, a system that is intended to prevent jamming in most of the psa group vehicles. there may be a curvature condition on the glass rails. suppositories and glass rails need to be checked. Maybe it can be corrected by coding. Can you lift it slowly with the glass button. sonerkyl 2019-10-17 09:27:39
08.05.2020 20:14 # 7
kaanbey34
Soner Bey, we did the coding you called, but it did not improve again. When the glass is closed to the top, it automatically opens 5-6 fingers. When we close it slowly, there is no problem when it is not fully seated, but the glass opens back when we do full safety closing with the remote control. Last time I forgot the glass was opened back until morning, theft, etc. Anyway, if it will rain, there will be trouble.
Confused
29.06.2023 22:28 # 8
wenceremos
Sir, mine also opens automatically when the window is closed. What did you do about this issue? I couldn't find a solution.
29.06.2023 22:29 # 9
wenceremos
Sir, did you find a solution?
