Solution of 307 steering pump buzzing sound
08.05.2020 14:53 # 1
bayelektronik
Friends who use the 307 is a very simple solution of the whistling sound coming from the electric power steering pump. He claimed that it would decrease very much even if he couldn't cut it. He said that it would cost 5 TL. The voice was so low that I can't explain it. It's not over, but it's too low. It's not disturbing. The previous voice in me was suppressing the engine sound.
08.05.2020 14:53 # 2
okan77
Get well soon ... We would appreciate it if you can add a picture ... also thanks for sharing
08.05.2020 14:53 # 3
bayelektronik
I did not pay any attention if it was seen from the top. Lifting the car removed the screws from the pipes of the steering pump from the bottom and attached it.
08.05.2020 14:53 # 4
Yes, there is a sound like whistling in the steering wheel. There is a styrofoam in the lower part of the steering wheel, which sometimes does it. But is it simple?
08.05.2020 14:53 # 5
Faruk
reno kangoo also made the sound of whirring when the oil had decreased, it was cut when added, but since it was able to whine, I am glad you solved the problem ..
08.05.2020 14:53 # 6
dbmaster
my car 2006 307 hdi this steering wheel oil where to put my friends
08.05.2020 14:53 # 7
[QUOTE = dbmaster] my car 2006 307 hdi this steering wheel where to put the oil when i can't find my friends [/ QUOTE]
There is a white spherical reservoir where the water to the radiator is placed. Right next to it is a little below, if it is not very dirty, there are red marks on the cover. I tried to mark in the picture. It says power steering on the cover.
08.05.2020 14:53 # 8
[QUOTE = bayelektronik] I did not pay any attention if it is seen from the top. He removed the car and removed several screws from the bottom of the steering pump pipes and inserted it.
Can we get the name of your service address? I am also uncomfortable, sometimes it is really uncomfortable with the sound.
08.05.2020 14:53 # 9
bayelektronik
Peugeot's authorized service.
08.05.2020 14:53 # 10
uarslan
Where did the authorized service done. We would appreciate if you give a clearer address. The quality and knowledge of all services are not the same as you will deserve.
08.05.2020 14:53 # 11
bayelektronik
Balıkesir center bell made automotive friends
08.05.2020 14:53 # 12
alpbeyazi
I don't have it from that voice, but I hope it doesn't come out tomorrow because I said "not available": S
08.05.2020 14:53 # 13
bayelektronik
[QUOTE = alpwhite] I don't have that voice in that voice but I hope it won't come out tomorrow because I said "not available": S [/ QUOTE]
The sound of the pump is because the power steering is electro power. The authorized service says normal. So the pump is not broken. Because it is electric, the sound is increased, they just cut the sound like this.
08.05.2020 14:53 # 14
hantsome28
while I turn the steering wheel, I feel as if something is hitting or rubbing at the bottom of the pedals in the driver's seat.
08.05.2020 14:53 # 15
ibrahim YILDIZAK
Can anyone write the name of that material?
08.05.2020 14:53 # 16
tolga35
as the subject is ready, friends can use it as steering oil.
which brand and model do you use?
08.05.2020 14:53 # 17
tolga35
friends no one know the brand and type of steering oil ???
08.05.2020 14:53 # 18
[QUOTE = tolga35] friends, no one knows the brand and type of steering oil ??? [/ QUOTE]
According to the original:
ESSO ATF D PR
TOTAL FLUIDE AT42
However, almost all ATFs will fit.
08.05.2020 14:53 # 19
Lion46
Totalin fluide type oil is used in Peugeot electric pump models (207-307-308-407). Lion46 2012-01-01 19:11:26
08.05.2020 14:53 # 20
tolga35
thank you friends..
Page : / 2
