SOLUTION FOUND TO THE SOUND FROM SUB
08.05.2020 17:04 # 1
GiTaRRa
friends came under my car, there was a sound in the bumps, almost like a pot of timbre, I couldn't find it in any master, couldn't find any master. Do you think the sound of the timbre is coming from the campaign? is that a big problem? knowledge?
friends are not able to solve this problem, we couldn't find it ... but the problem has been solved as of today. There are plastic bushes just behind it, the cover has changed, it seems like it was wasted on the shaft inside it. The problem has been solved. No problem, almost some masters said we will lower 1,000 axles. there are still masters ... if there is a sound from the bottom, do not forget to look directly at that area, friends ..
GiTaRRa 2012-10-08 23:12 : 57
08.05.2020 17:04 # 2
berk2309
can I come from them as far as i know there is a bow in the campaigns & nbsp;
08.05.2020 17:04 # 3
GiTaRRa
it might be my guess, for example. I pull the hand brake, I force the car back and forth, it gives a squeaking sound ... but I do not know how long the connection is there.
08.05.2020 17:04 # 4
berk2309
Could I also come out of the wire, the hand brake should have the wire checked & nbsp;
08.05.2020 17:04 # 5
GiTaRRa
yes first I think it is necessary to show the wire in the next periods, if it is not to be done in order.
08.05.2020 17:04 # 6
berk2309
I do not think you will come from the ball because it makes a sound as it freezes, even though it has spread & nbsp;
08.05.2020 17:04 # 7
GiTaRRa
we are in the same opinion .. thank you.
08.05.2020 17:04 # 8
berk2309
I hope you can ask for accident-free surprises, whether it's a cheap thing or not.
08.05.2020 17:04 # 9
sarp
If there is a buzzing sound and the sound is coming when the feet rest on the wheels and it gives a feeling of emptiness, the middle hubs are loose, they have come to me, they are removing the wheels, they are tightening the hubs, the problem is being solved.
08.05.2020 17:04 # 10
GiTaRRa
I couldn't go to the industry yet, but yours overlaps this event. So I can go for a couple of days.
08.05.2020 17:04 # 11
carantinas
It can be in torsion balls and amartisors .. & nbsp;
08.05.2020 17:04 # 12
Quiksilver_106
Get well .. there is a voice close to him in me, it sounds like a marble, it is probably coming from the same area behind them ..
08.05.2020 17:04 # 13
GiTaRRa
tsk ... if it sounds like a ball hitting the ball, that sound is my friend ..
