solenoids exchange
08.05.2020 15:14 # 1
ozi033
I decided to replace these solenoids in my 307 car because it is malfunctioning. how will we provide.It will find the place we have made, or we will order from somewhere.
08.05.2020 15:14 # 2
My teacher friend had changed 4 celloids to 500 TL 4 years ago to a good automatic transmission master in maslak industry. you share yourself from there :)
08.05.2020 15:14 # 3
[QUOTE = maverick sbd]
or use tiptronic if you won't bother. then you eat from gas. friend, we resisted quite a lot ... I will use tiptronic and make a lot of money. but eventually he had to take it. There are good auto masters in maslak. they are also guaranteed.
08.05.2020 15:14 # 4
The site has sponsors. Even one (Sahin Peugeot) can supply the original spare part. You can ask him about the topical.
08.05.2020 15:14 # 5
ozi033
[QUOTE = maverick sbd] [QUOTE = maverick sbd]
[/ QUOTE] I can't use triptonic ... it is already converted to automatic.
08.05.2020 15:14 # 6
BAHTIYAR
I do not put the vehicle into the industry in a small place, I think you need to buy 180 lira 2 pieces of celonoid in a vital piece like helical gearbox + workmanship + oil + fit 700 meters.
08.05.2020 15:14 # 7
mimitt
If you mean a small place, it means you have never been to Antep :) it is a very beautiful city, if there is a place in your city that deals only with automatic transmissions and guarantees the work it does, I think it should be your first choice, even in the authorized services, the masters do not have a lot of knowledge about automatic, valves may be defective, but valves has it expired my life or is there another factor that disrupts the valves, this should be investigated, personally, the valve changed 3 times in my car, the transactions were done in the authorized service within a year, 5 months after the last operation, when it failed again, they made me a cost of 2.800 TL. I found a master, they are just doing automatic gear repair, I left the car the next day, he said to me that the brain was cracked and had to change, the problem was solved from the root with a total of 800 pounds of oil, 2 main valves, and oil change.
08.05.2020 15:14 # 8
metin
I think you have the wrong solenoid valves two. they make it to 450 including oil.
08.05.2020 15:14 # 9
metin
Sorry my friend, but either you are telling it wrong or what I know is wrong. Even if you use the vehicle in triptonics, nothing changes. The brain automatically commands the change valves to the valves. In triptonics, you give the command to replace selanoids.
08.05.2020 15:14 # 10
metin
[QUOTE = ozi033] [QUOTE = maverick sbd] [QUOTE = maverick sbd]
The gearbox fixes itself to 3rd gear in order to go to the service in case of malfunction. Even if you take triptonics, "D" appears on the screen and it does not switch to triotonics. Take it to snow mode in case of malfunction takes you to where you want, my automatic transmission master said so.
08.05.2020 15:14 # 11
ekinoks44
My 2003 model otm. I have a gear 206 vehicle. Snow and S light blink when running. Sometimes the car's pulling on the slope falls strange, the moans officially sound like blunt when reversing. I went to the master, he said that the solenoid valves will change and said that he would hold 450 rubles. However, a friend said that the problem will be solved when the gearbox oil is changed and the valves are cleaned. What should I do?
08.05.2020 15:14 # 12
metin
[QUOTE = ekinoks44]
if you can, replace the valves, if not, then change the oil only to replace the valves.
