Solenoid valve selection?
08.05.2020 17:01 # 1
kuantum
I will buy a new solenoid valve on my vehicle in my signature. Can someone help me choose a valve that is compatible with my vehicle in this regard?
08.05.2020 17:01 # 2
Because the transmission type is AL4, the solenoid type you will get is 206 or 307 and it is unique.
http://www.peugeotmarket.com/ELEKTROVANASELENOIDTUM-MODELLER,PR-2.html
08.05.2020 17:01 # 3
kuantum
[QUOTE = koliva] Because the transmission type is AL4, the solenoid type you will get, whether 206 or 307, is unique. 2.html "target =" _ blank "rel =" nofollow "> http://www.peugeotmarket.com/ELEKTROVANASELENOIDTUM-MODELLER,PR-2.html
hi, am I going to get two of these, how do we do it? Is this a set? and is this also a new type of solenoid?
08.05.2020 17:01 # 4
yenice
PEUGEOT AND CIRTOEN FOR ALL AUTOMATIC GEAR VEHICLES
OUR PRODUCT is PEUGEOT ORIGINAL PRODUCT.
ALWAYS USE THIS PRODUCT WITH ITS OWN ORIGINAL OIL (LT 71141 MOBILE) BUY 3 PIECES
This is how it writes in its descriptions. that is, not in a set If you want to get information on this site, it will be healthier.
08.05.2020 17:01 # 5
[QUOTE = quantum]
hi, will I get two of these or something, how do we do it? Is this a set? and is this a new type of solenoid?
First of all, I would like to see if solenoids are defective. Faulty is how many are faulty. You will change it according to him. I am sure that the solenoids in your vehicle are defective. That's why I say so.
08.05.2020 17:01 # 6
kuantum
thanks. What should I do to understand that the solenoid is defective? I will have it connected to the computer. But what error can I say that the solenoids are faulty? The gear shifts were basically staggering to me, now the gearbox faults on slopes. every day on the same slope, in the same places ..
08.05.2020 17:01 # 7
[QUOTE = quantum] Thank you. What should I do to understand that the solenoid is defective? I will have it connected to the computer. But what error can I say that the solenoids are faulty? The gear shifts were basically staggering to me, now the gearbox faults on slopes. and every day on the same slope, in the same places .. [/ QUOTE]
Sir, get you connected to the computer and get all the error codes and write them here. Let's discuss it after that. I want the error codes themselves, not just the description of the error codes. Like P0123. Reviews
08.05.2020 17:01 # 8
kuantum
OK thanks.
08.05.2020 17:01 # 9
kuantum
[QUOTE = koliva] [QUOTE = quantum] thanks. What should I do to understand that the solenoid is defective? I will have it connected to the computer. But what error can I say that the solenoids are faulty? The gear shifts were basically staggering to me, now the gearbox faults on slopes. and every day on the same slope, in the same places .. [/ QUOTE]
Does
show if I connect it to any computer? What software should the guys have to see the error codes? and how many money do they make? If not, I will go to an industrial site tonight and let me connect.
08.05.2020 17:01 # 10
[QUOTE = quantum]
Does
show if I connect it to any computer? What software should the guys have to see the error codes? and how many money do they make? if not, I will go to an industrial site tonight and let me connect.
I have no knowledge of the fee. There are readers of different types, but it is PP2000 that is unique to Peugeot. If you want, call the authorized service and get a price. They may not want to share the error codes, talk to the beginning.
08.05.2020 17:01 # 11
kuantum
[QUOTE = koliva] I have no knowledge of the fee. There are readers of different types, but it is PP2000 that is unique to Peugeot. If you want, call the authorized service and get a price. They may not want to share the error codes, talk from the beginning. [/ QUOTE] Hi, only at your request, I went to a service and got my car connected to the computer. The official wrote on the paper: Error code P1701 (Transmission gear mismatch) Pressure adjustment failure Difference 1 / recommendation 03 091 Gearbox input speed signal failure no signal Can engine torque information no signal desired pressure 270 (I mean 2.70) oil pressure 230 (2.30? My observations are as follows; I asked the official, I said how the oil pressure is, he said lower than desired. This is obvious when he starts and moves the vehicle anyway, he said to me there was a slight knock. I had it checked in the same place before, then the oil pressure was low, but I tried changing and correcting the transmission oil, but unfortunately I couldn't see its benefit. After changing the structure, the master at the place I changed had said that the oil pressure returned to normal, but then there was knock again. The oil did not help at all. Also, my car does not slide back on inclines. I don't think there is a deep gearbox problem. There is only a reduction in knocking and traction in gearshifts. It burns a little too much. It is said that the problems with solenoid valves may also affect the fuel. Recently, when the vehicle is cold and especially in sloping areas, the vehicle pushes forward and gives chance of chance: "Faulty Gearbox" However, there is no transition to winter and sports mode. It only gives errors and the traction of the vehicle drops a lot. The error screen goes off when you stop and restart. The vehicle is returning to normal.I had been suspecting solenoids for about a year, but I resisted for this expense even though I changed the gearbox oil to the fallon. I am now tired of making mistakes on slopes, I am afraid that it may also damage the transmission. So I seem to have decided to replace solenoid valves. But I was confused because you said, "I'm not sure the problem is from the solenoid valve," and my solenoids are new. That's how it is. Now I am waiting for your comments and suggestions. Also: Is there a method that we can understand which solenoid is defective, or should I change both when it is changed ..? quantum2012-11-26 15:13:10
08.05.2020 17:01 # 12
msertkol
It is called pressure error, but whatever is wise, it does not work in gasoline. Last morning, I went for 2 km just petrol, I came to the full inclined road, I said to take the LPG. Error appeared. When it restarted it passed. He didn't do that day any more.
& nbsp; & nbsp; No undoing. In-city consumption in Istanbul is around 25-27 kurus. Trip computer 8.4LT / 100km. Vehicle LPG li.
& nbsp; & nbsp; I started the starter this morning and waited for 2 minutes to let the engine warm up; (D) I waited for the car for the last 1 minute. Then I put it in reverse gear (R) and waited. I don't know if it helped the problem, but I didn't get hit this morning. I will also try it when the engine is cold next. & Nbsp;
& nbsp; & nbsp; They looked at the gas settings in the BRC service as well. & nbsp;
& nbsp; & nbsp; Let's share our experiences, try it.
Regards.
08.05.2020 17:01 # 13
kuantum
He does it on me too, he's not just making a mistake, he's jolting through gears at normal times. & Nbsp;
08.05.2020 17:01 # 14
kuantum
unfortunately no one commented on the subject I still wrote above :(
08.05.2020 17:01 # 15
kuantum
the question is up to date.
08.05.2020 17:01 # 16
msertkol
quantum, what is your situation, is this problem solved?
08.05.2020 17:01 # 17
serkomser
As I have the same problems, it does not shake in triptonics from 1 to 2, as well as knock.
2. I have a problem with shaking on the hill and not eating gas. The car burns like 15 liters and rarely knocks when passing to 2.
& nbsp;
eurest 2014-04-07 11:58:32
08.05.2020 17:01 # 18
ercanayman
Hi, at your request, only today I went to a workshop and got my car connected to the computer. The official wrote on the paper: Error code P1701 (Transmission gear mismatch) Pressure adjustment failure Difference 1 / recommendation 03 091 Gearbox input speed signal failure no signal Can engine torque information no signal desired pressure 270 (I mean 2.70) oil pressure 230 (2.30? My observations are as follows; I asked the official, I said how the oil pressure is, he said lower than desired. This is obvious when he starts and moves the vehicle anyway, he said to me there was a slight knock. I had it checked in the same place before, then the oil pressure was low, but I tried changing and correcting the transmission oil, but unfortunately I couldn't see its benefit. After changing the structure, the master at the place I changed had said that the oil pressure returned to normal, but then there was knock again. The oil did not help at all. Also, my car does not slide back on inclines. I don't think there is a deep gearbox problem. There is only a reduction in knocking and traction in gearshifts. It burns a little too much. It is said that the problems with solenoid valves may also affect the fuel. Recently, when the vehicle is cold and especially in sloping areas, the vehicle pushes forward and gives chance of chance: "Faulty Gearbox" However, there is no transition to winter and sports mode. It only gives errors and the traction of the vehicle drops a lot. The error screen goes off when you stop and restart. The vehicle is returning to normal.I had been suspecting solenoids for about a year, but I resisted for this expense even though I changed the gearbox oil to the fallon. I am now tired of making mistakes on slopes, I am afraid that it may also damage the transmission. So I seem to have decided to replace solenoid valves. But I was confused because you said, "I'm not sure the problem is from the solenoid valve," and my solenoids are new. That's how it is. Now I am waiting for your comments and suggestions. Also: Is there a method that we can understand which solenoid is defective, or should I change both when it is changed ..? [/ QUOTE] Hello, has the above solution been resolved? I have the same problem now ercanayman2018-10-24 22:45:50
08.05.2020 17:01 # 19
ercanayman
[QUOTE = ercanayman] Hello, as you requested, I went to a service today and got my car connected to the computer. The official wrote on the paper: Error code P1701 (Transmission gear mismatch) Pressure adjustment failure Difference 1 / recommendation 03 091 Gearbox input speed signal failure no signal Can engine torque information no signal desired pressure 270 (I mean 2.70) oil pressure 230 (2.30? My observations are as follows; I asked the official, I said how the oil pressure is, he said lower than desired. This is obvious when he starts and moves the vehicle anyway, he said to me there was a slight knock. I had it checked in the same place before, then the oil pressure was low, but I tried changing and correcting the transmission oil, but unfortunately I couldn't see its benefit. After changing the structure, the master at the place I changed had said that the oil pressure returned to normal, but then there was knock again. The oil did not help at all. Also, my car does not slide back on inclines. I don't think there is a deep gearbox problem. There is only a reduction in knocking and traction in gearshifts. It burns a little too much. It is said that the problems with solenoid valves may also affect the fuel. Recently, when the vehicle is cold and especially in sloping areas, the vehicle pushes forward and gives chance of chance: "Faulty Gearbox" However, there is no transition to winter and sports mode. It only gives errors and the traction of the vehicle drops a lot. The error screen goes off when you stop and restart. The vehicle is returning to normal.I had been suspecting solenoids for about a year, but I resisted for this expense even though I changed the gearbox oil to the fallon. I am now tired of making mistakes on slopes, I am afraid that it may also damage the transmission. So I seem to have decided to replace solenoid valves. But I was confused because you said, "I'm not sure the problem is from the solenoid valve," and my solenoids are new. That's how it is. Now I am waiting for your comments and suggestions. Also: Is there a method that we can understand which solenoid is defective, or should I change both when it is changed ..? [/ QUOTE] Hello, has the above solution been resolved? I have the same problem right now
08.05.2020 17:01 # 20
[QUOTE = ercanayman] [QUOTE = ercanayman] Hi, only at your request, I went to a service and got my car connected to the computer. The official wrote on the paper: Error code P1701 (Transmission gear mismatch) Pressure adjustment failure Difference 1 / recommendation 03 091 Gearbox input speed signal failure no signal Can engine torque information no signal desired pressure 270 (I mean 2.70) oil pressure 230 (2.30? My observations are as follows; I asked the official, I said how the oil pressure is, he said lower than desired. This is obvious when he starts and moves the vehicle anyway, he said to me there was a slight knock. I had it checked in the same place before, then the oil pressure was low, but I tried changing and correcting the transmission oil, but unfortunately I couldn't see its benefit. After changing the structure, the master at the place I changed had said that the oil pressure returned to normal, but then there was knock again. The oil did not help at all. Also, my car does not slide back on inclines. I don't think there is a deep gearbox problem. There is only a reduction in knocking and traction in gearshifts. It burns a little too much. It is said that the problems with solenoid valves may also affect the fuel. Recently, when the vehicle is cold and especially in sloping areas, the vehicle pushes forward and gives chance of chance: "Faulty Gearbox" However, there is no transition to winter and sports mode. It only gives errors and the traction of the vehicle drops a lot. The error screen goes off when you stop and restart. The vehicle is returning to normal.I had been suspecting solenoids for about a year, but I resisted for this expense even though I changed the gearbox oil to the fallon. I am now tired of making mistakes on slopes, I am afraid that it may also damage the transmission. So I seem to have decided to replace solenoid valves. But I was confused because you said, "I'm not sure the problem is from the solenoid valve," and my solenoids are new. That's how it is. Now I am waiting for your comments and suggestions. Also: Is there a method that we can understand which solenoid is defective, or should I change both when it is changed ..? [/ QUOTE] Hello, has the above solution been resolved? I have the same problem right now [/ QUOTE] if you get it on your chassis, a friend can get a solution like this, the probable solenoid replacement will be made in your vehicle, but it may be necessary to try this method first. I https://forum.peugeotturkey.com/forum_posts.asp?tıd=47214&title=peugeot-307-otomatik-vites-arizasi-cozul
Page : / 2
