Solenoid valve replacement
08.05.2020 18:36 # 1
deniz26
I have had a problem with my car for the past ten days. When driving on a straight road at a normal speed, where the gear indicator on the instrument panel is located, the * and S marks are flashing in the lower right and upper parts of the D icon. First a beep twice and then these signs are flashing. then it goes back on its own. I heard that in such a problem, the solenoids should change, the price of which is 200 tl www. peugeotmarket .com / da 100 tl. it says it was original. I wanted to consult you. one said they need 3 from the service but everybody says there are two confused. I never understand from these issues ...
08.05.2020 18:36 # 2
serkomser
Hello, I have 2 new generation Solenoid valves with 100 Hz black cap. I can give the one from 50.00TL. If you try first, if the master approves, I will take the fee accordingly (I do this for Garanti)
08.05.2020 18:36 # 3
GokhaN
You can buy peugeotmarket, if it says original, it is original.
08.05.2020 18:36 # 4
outlaw
[QUOTE = eurest] Hello, I have 2 new generation Solenoid valves with 100 Hz black cap. I can give the one from 50.00TL. If you try first, if the master approves, I will take the fee accordingly (I do this for Garanti) [/ QUOTE]
THIS MORE LOGIC AND FRIEND IF YOU WANT A LOOK AT THE TIME TO TRY ... ClapClapClap
08.05.2020 18:36 # 5
deniz26
How do I get it from you?
08.05.2020 18:36 # 6
evooz
I can give to me in Ankara under the same conditions
08.05.2020 18:36 # 7
deniz26
Unfortunately I am in Eskişehir
08.05.2020 18:36 # 8
Foxfire
I can buy if I don't get friends
08.05.2020 18:36 # 9
serkomser
[QUOTE = deniz26] How do I get it from you, well ... will I also warn 206 [/ QUOTE]
I will ship with Free Shipping. Solenoid Valves are one type fits all models.
[QUOTE = Foxfire] if I don't get friends I can
It doesn't matter. If there is no sound from the friend, the priority is Deniz26.
Eurest 2014-06-11 09:59:36
08.05.2020 18:36 # 10
Foxfire
Okay I need it because I'm waiting for news
08.05.2020 18:36 # 11
gemlikli_55
What happened to the FOXFİRE vehicle :)
08.05.2020 18:36 # 12
Foxfire
[QUOTE = gemlikli_55] What happened to FOXFIRE vehicle again :)
Well, everything was fine, the snow and sports lights started flashing on the way again. Dead I changed it 2 months ago, I didn't like the type of those guys anyway, they wore certain imitation goods. I deleted the error anyway.
08.05.2020 18:36 # 13
serkomser
I sent Foxfire (Gencay) Valves.
08.05.2020 18:36 # 14
HCey
I have the same problem. I went to the service. They said that the electric valves and gearbox oil will change and the cost is around 750 TL. Generally, there was a problem with oil reduction or oil contamination in all automatic cars.
