Solenoid valve malfunction ??
08.05.2020 21:04 # 1
akyuz.cagri
Hello, I have been running the vehicle for 3 or 4 times while running the car for a while, they said solenoid valve replacement, fluctuations have started in the vehicle cycle for 3 days, I wonder if this cycle fluctuates from the valve? Because it happens in all gears, if they have made a solenoid valve change between you, can they give me place and price?
08.05.2020 21:04 # 2
Levent206xt
solenoid valve regulates gear shifts.
08.05.2020 21:04 # 3
idling ripple is related to throttle - spark plug - coil - injector.
08.05.2020 21:04 # 4
arachnid
I had the ripple as well. Idling engine changed, no problem.
08.05.2020 21:04 # 5
akyuz.cagri
[QUOTE = Levent206xt] regulates solenoid valve shifts. Does not make idle fluctuations. [/ QUOTE]
It seems like he's shifting a little late to 3rd gear ... is that about valve or could it be about gears? The transmission was revised 3 years ago ... ??
08.05.2020 21:04 # 6
akyuz.cagri
today we connected the vehicle to the device ... no problems with the gearbox or solenoid ... they directed it to the brain master, ... the situation that we think is caused by the solenoid valve may originate from the brain, I will write to the attention of those who follow the subject, after the brain master.
