Software and Failure
08.05.2020 19:16 # 1
EdizSaral
Hello guys, I just joined you, hi everyone,
2005 1.6 hdi 110 hp I have 2005 My lone engine is a complete c4 engine.
Anyway; We have taken the software very light up to 15%. There was no problem, the malfunction lamp was lit, the light was extinguishing, etc ... when it was connected to the computer, it was saying too much turbo pressure.
I started the car today, I did not go 5 meters, my speed was around 30, the car was clogged, the gas cut off, the engine light turned on, and the stop started flashing. I stopped it, started it again, the engine light was on, but there was no gas on the way, there was no problem. is it from this software? or from fuel filter etc?
Today, I will restore the old software. After this installation, I should do this to reset the malfunctions in the brain. If I throw the old software and continue, is it enough to have it connected to the computer ??
Thanks
08.05.2020 19:16 # 2
GokhaN
We probably get from the software, after you install the original software, just connect the computer, just in case there are malfunctions, they will reset. I don't think there will be a problem
08.05.2020 19:16 # 3
EdizSaral
[QUOTE = GökhaN] is probably from the software, after you install the original software, just connect the computer, just look at it if there is a malfunction. I don't think there will be a problem [/ QUOTE]
Thanks, well, after throwing out old software, there is a brain reset event. Do I need to do this? Do you think it is necessary?
