|   | software |
| 08.05.2020 18:17 | # 1 |
|  hakan574 | |
| 08.05.2020 18:17 | # 2 |
|  outlaw | |
CHIP TUNING IS A NEW SOFTWARE WHAT YOU HEAR ...
| 08.05.2020 18:17 | # 3 |
|  hakan574 | |
so he will make changes in his traction. I don't know what it is but where can I find how many money it is and is the unit of the original parts of the vehicle
| 08.05.2020 18:17 | # 4 |
|  outlaw | |
| NEW PROGRAM INSTALLED IN THE BRAIN OF THE CAR .. A MINIMUM OF 500 AS A PRICE ... | |
| 08.05.2020 18:17 | # 5 |
|  herry | |
If traction is a problem, first go to a good master and have the engine inspected. Operations such as chip tuning software are applied for power increase in healthy engines. I think you should first check your car's maintenance. Let them look at parts such as injectors, coils and spark plugs. If there is a traction problem, let them handle it first. Everything is fine then consider software.  | |
| 08.05.2020 18:17 | # 6 |
|  furkanyakar | |
I would also like to have the tube and gasoline filter checked and use an injector opener with half a tank of gasoline. If chip tuning is not available, I would not recommend it as a waste of money. There is no operating system such as windows in vehicles, a new one for 2 years;)
| 08.05.2020 18:17 | # 7 |
|  hakan574 | |
As you say you are right, I am a good person to the service, but I think the injector was not checked, I think I should use it painfully, thank you very much for the information you provided.
| 08.05.2020 18:17 | # 8 |
|  furkanyakar | |
You're welcome writes Kahramanmaraş at your location. I'm also a maraşş if I can help, I will do my best.
| 08.05.2020 18:17 | # 9 |
|  herry | |
I used pro tech fuel cleaner, I recommend it works. I bought 40 TL from maslak. As Furkan says, put at least half a tank of gasoline in the car, add pro tech to the tank while buying gas. he will do his job.  edit: narration | |
