SMOKE FROM 307 HDI OIL COVER
08.05.2020 18:38 # 1
cerit307
307 HDI USERS ARE THE SMOKE FROM THE OIL COVER IS NORMALIZED. cerit307 2014-06-24 14:47:23
08.05.2020 18:38 # 2
madblueblacksea
If the same smoke comes from the dipstick, you say that it is likely to be missing, but there is no oil reduction. (Engine exhausted in folk language) If it comes only from the oil cap, it may be missing from the valve seals. By putting the engine into the compressor test, you can find out where the problem is and the state of the engine
08.05.2020 18:38 # 3
samet2461
If my master sounds a little, it's okay. my 307 1.6 hdi dende comes in white steam. There is a problem if it comes from the dipstick, if it is a little, if the engine is hot, there is no problem. I say look when the engine is cold
08.05.2020 18:38 # 4
cerit307
http://www.izlesene.com/video/14-tdci-ford-fiesta-motor-uflemesi/2622387#
Coming up the vehicle attached in the link
08.05.2020 18:38 # 5
samet2461
when the engine is hot or cold
08.05.2020 18:38 # 6
cerit307
08.05.2020 18:38 # 7
samet2461
When my teacher got it, is that white smoke coming when the car is cold or hot? Also how many thousand vehicles samet2461 2014-06-24 15:48:54
08.05.2020 18:38 # 8
cerit307
Coming while it's hot bro
08.05.2020 18:38 # 9
samet2461
When it is cold, it will probably not look at it. oil mist fumes if it does not come when it is cold. how many thousandth vehicle
08.05.2020 18:38 # 10
cerit307
the vehicle has no problem at 180000 pulling, no noise in the mtor works like clockwork 3000 km a tea glass of oil decreased
08.05.2020 18:38 # 11
cerit307
there is nothing changing in the same way as the vehicle in the video. Could you find the opportunity to watch the video?
08.05.2020 18:38 # 12
samet2461
As my master said, check it out when it's cold. There is nothing in the car. In my old 206 cars, 40 masters spoke differently to that white steam event. If the oil does not diminish, be comfortable
08.05.2020 18:38 # 13
cerit307
my brother is confused and a master says no problem other master says it needs to be rushed urgently, it was a month since I bought the car, I got salt ice with a whim against the car
08.05.2020 18:38 # 14
hsnsnl
When my teacher opens the oil cap of the engine because he is eccentric, he always throws the oil vapor every time. This situation does not change at any time. see more clear cvp can be given ..
08.05.2020 18:38 # 15
cerit307
You say it's normal, don't you think it's okay?
08.05.2020 18:38 # 16
hsnsnl
[QUOTE = cerit307] you say it's normal, do you think it's okay? , low oil reduction is normal.
08.05.2020 18:38 # 17
cerit307
performance is very good, even very good, I showed it to libadiye peugeot special service.
08.05.2020 18:38 # 18
cerit307
if you want to check the smoke it throws at the same rate with this vehicle
08.05.2020 18:38 # 19
samet2461
If you look carefully at the author under the video, the guy at the bottom made the following statement.
"It is normal for diesel engines to get steam from the oil cap or oil dipstick when idling. This is not a sign that the engine is exhausted. The test you are exhausted can only be done by compression measurements and / or measurement of the circulation bearings by a professional reciter ..."
last point . Wink
08.05.2020 18:38 # 20
jack67
I did not encounter such a smoke of 215,000 km of 215. But it does a reduction like 100ml from 4lt oil. I asked the master I went to, he said, "Is it a normal reduction?"
Page : / 2
