smoke comes out of the dipstick |
| 08.05.2020 15:19 | # 1 |
| 08.05.2020 15:19 | # 2 |
This topic goes through blow-by. My advice to you is to open the oil filler cap on the engine blog while the engine is running and watch the smoke there. A little smoke is normal.
| 08.05.2020 15:19 | # 3 |
oguzhan29 |
If you turn it on when the engine is hot, smoke will come out.
| 08.05.2020 15:19 | # 4 |
There was smoke coming out of the oil filling area, but not excessive smoke, not when the engine was hot, I started it in the morning, after 2 km, I looked, I removed the oil pouch, it does not blow, it just comes out like a light cigarette smoke.
| 08.05.2020 15:19 | # 5 |
look at the exhaust, let's see the bluish smoke, give a little gas to the car
| 08.05.2020 15:19 | # 6 |
A little smoke is normal. Do you know what kind of oil is put in the car? Keep an eye on the cooling water. Watch it and see, does water decrease? |
| 08.05.2020 15:19 | # 7 |
When the engine is hot, it is normal to get oil vapor out of it ... If you give up to 5000 cycles of gas in the moment, there is no problem if the blue smoke does not come out of the exhaust.
| 08.05.2020 15:19 | # 8 |
slm friends I showed the car today, the master exhaust fumes are normal, no problem, because the bad fuel is bad, the diesel filter changed oil and fuel, I added additives to the fuel and the engine sound improved but today I was in the city for a little while the temperature was too low 90. I did not clean the bidet fuel tank, because there was dirty fuel left in it. the master said that the diesel filter may go, if the overheating needle escapes in these vehicles, there will be complete danger.
| 08.05.2020 15:19 | # 9 |
oguzhan29 |
They open fans at 105 or 110
| 08.05.2020 15:19 | # 10 |
Maybe it is unlikely, but because I have encountered it, I am telling you, whatever your oil level is, it may have an effect even if there is a lack of oil or oil change time. |
| 08.05.2020 15:19 | # 11 |
oil has just changed, I am wondering if the dirty fuel in the tank runs out in time or do I need to clean the tank, will it damage the injectors?
