SMEG SCREEN IS NOT EMERGENCY PLEASE HELP
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:49 # 1
mrtavcii
Hello, when you turn the ignition, the screen does not appear. It does not appear in a Bluetooth connection.
08.05.2020 20:49 # 2
First of all, welcome to us. If you do not have a problem with fuses, there is a problem on the screen. It is a little difficult to find an electronics store to do this domestically. You can see this problem on overseas sites. Unfortunately, there is no other way to change it.
08.05.2020 20:49 # 3
GokhaN
I don't think there is anything on the screen because you said the battery is working when you remove the polarity head. While trying to open the screen, I do not think that it is a very important thing because it cannot control the situation and get an activity. Let's take a look at the battery, what is the situation?
08.05.2020 20:49 # 4
Aybars
I have the same problem, guys. I'm tired of removing and wearing the pole every day. I showed many electricians and electronics, but there is no solution. Because of this problem, I even think of selling my vehicle. Please, I would appreciate if a friend who has knowledge and feelings about it helps.
08.05.2020 20:49 # 5
Burak1910
If the problem is solved, master, I have the same problem, but the screen does not come when the pole is disconnected and turned on, the lights on the buttons turn on when I turn on the stops, today I took it to abc, just asked for a pale figure like 300 TL for damage detection, for me, if anyone knows a place to solve the job in Ankara I would be glad if it helps
08.05.2020 20:49 # 6
Oguz_ua
my current friends came to me just before i was sitting in the car with the ignition off. I was listening to the radio, then I turned it off, I got the radio back in 1 hour, and the car does not turn on the screen. The keys are light but the screen is not. Let's put the polar heads tomorrow.
08.05.2020 20:49 # 7
kimiraikkonen
The same problem happened to me for the third time in the last 1 year and repeating. There is no solution other than removing the battery positive terminal.
The day I bought a Peugeot was damned by my curse.
Stay away from 208, gentlemen.
the kimiraikkon 2019-04-01 02:07:15
08.05.2020 20:49 # 8
kimiraikkonen
If anyone can find a solution please write? Thanks.
I wonder if the Peugeot Turkey in case lying on this issue, ending the guarantee is doing what people do? I'm in this situation right now.
08.05.2020 20:49 # 9
I do not remember exactly such complaints in foreign forums, but there were comments as a result of resistance on the screen. Unfortunately, there is no solution for a long time, I was not looking at the foreign problems for a long time. Let's do some research.
08.05.2020 20:49 # 10
kimiraikkonen
[QUOTE = sonerkyl] I do not remember exactly such complaints in foreign forums, but there were comments as a result of a resistance on the screen. Unfortunately, there is no solution for a long time, I was not looking at the foreign problems for a long time. Let's do some research. [/ QUOTE]
Sir, thank you very much for your answer. I looked at 208 biggest foreign forum called 208ownersclub. The exact same problem has been reported. Doesn't the Peugeot guarantee a free Smeg replacement taking into account these even after the warranty ends? These attitudes are not fair and moral at all.
If you get any information, please let us know.
Greetings.
08.05.2020 20:49 # 11
kimiraikkonen
This problem occurred again to me the other day. As far as I learned, the Smeg module needs to be replaced (mus). I got cold from this vehicle. My 9-year-old Toyota car has none of these problems.
08.05.2020 20:49 # 12
Orcun.Dmr
[QUOTE = kimiraikkonen] This problem reappeared to me the other day. As far as I learned, the Smeg module needs to be replaced (mus). I got cold from this vehicle. My 9-year-old Toyota car has none of these problems. [/ QUOTE]
Because there is nothing on behalf of the hardware that can make a malfunction in the toyota, which recently lacks paint peeling, airbag problems and engine malfunction.
08.05.2020 20:49 # 13
cosinus
I also have a screen that turns on and off, it hasn't been said 2 years later, the screen goes on and on, whatever happened, the screen always goes and goes, the battery is unplugged and attached 1 day went smoothly, but the next day I went to the car, there is no problem working radio.
I started the vehicle on the turn, started shutting and opening does not work for 1 minute.
09.07.2021 11:43 # 14
seckins
Hello guys.
This solution to the problem (I tried it myself and it worked):
Remove and remove the device behind the screen.
There is a fan on the left side of the device. The problem is the fan. It's powder coated and doesn't function or the tabs are loose and won't turn at all.
Open the device (if you're not confident it let someone understand)
There are 2 cards on top of each other in a plastic case. When you remove them, you will see that the fan is mounted with only two nails. It will be seen that the surface that the nails touch is also worn and not in full contact.
Clean both surfaces thoroughly, clean the fan thoroughly. Bend the tabs up a little (make good contact).
Now roll them back and attach them to your car.
Get well soon.
27.07.2021 08:45 # 15
mrtavcii
Hi, resetting from battery and resetting from fuse doesn't work anymore. When I called the service, he said, we dismantle the screen and send it to the agreed places, we are not interested, etc. I'm thinking of replacing the screen with an android multimedia screen. Do you think it will be a solution? Or have you been able to develop an alternative solution for the smeg screen not opening? Respects.
