SLM EMERGENCY AID FRIENDS
08.05.2020 14:53 # 1
boynerx
FRIEND is your HEI 1 WEEK WAS 307 PREMIUM FULL THE 2004 MODEL Triptonik Transmission REFER TO LOWER TOOLS TOP 5 km NORMAL TRANSMISSION expense D ON SCREEN BUT Right on the S LETTER UP BUT YACHT S WRITES VİTESTEK PROFIT PICTURE SCREEN UP BUT PRINTING I PRINTING I CAR IN ONE GEAR shouting going STOP I Agree NORMAL to A FROZEN SURE ASK THE SAME SEASON I STOP AND CONTINUE SOME TIMES I REMOVE THIS FRIENDS CAN I GET HELP FROM THE KNOWLEDGE
08.05.2020 14:53 # 2
boynerx
I asked the person I bought the vehicle when I was going on the road, it goes to the sport mode, I press the side, shouts what the gear shifts nee embraces, I said to me, I have the letter S next to the gear lever, if it passes, he says he will fix it, I do not fix it, but the vehicle does not fix it without a tour, it does not fix without spotting. There are tupes, I do this when I switch to the tupe, so I have to stop and run again to switch to the normal automation. It does the problem for the first time, but it does this frequently in the first run. tickling is going to be 4 tae point, it doesn't get fixed until I stop, why is this araads if I repair it without hurting a big damage or is it normal?
08.05.2020 14:53 # 3
Onur
the gearbox is not related to the lpg. When the lights flash, the gearbox works in emergency mode only uses the 3rd gear, most likely the gearbox will change the valve.
08.05.2020 14:53 # 4
300yedi
If the picture of snow comes to the screen, it is not in sport mode but in snow mode, that is, it works in snowy mode.
08.05.2020 14:53 # 5
If there are signs such as s - * in the gear information screen where you should type D, if you do not press it, it is the automatic transmission malfunction. Show it to an automatic transmission urgently or return it to where you bought it. The cost is not less, you can change the gearbox with a minimum of 500 and a maximum in automatic, either as an exit (4-5 thousand lira) or oricinal (10-12 thousand lira) Numbers are the information I get from the forums. They are not exact figures. I have looked at what I would do if the malfunction came out of the same vehicle.
GET WELL SOON. I hope this is not an error.
