slight jolt and engine noise
08.05.2020 19:19 # 1
Demir42
Hello friends, I just registered
I have a Peugeot 308 gasoline 2010 model automatic car. A problem started about 1-2 months ago.
The problem is that when I move with the car in the light or elsewhere, the sound rises in the engine, it feels like it gives off gas, it does this slight reaction 2-3 times after it stops. When I stop somewhere after 5 minutes again, what is the problem? Vehicle at 52 thousand Demir42 2015-06-10 05:16:18
08.05.2020 19:19 # 2
Welcome, first of all, my teacher has a throat butterfly cleared in your vehicle.
08.05.2020 19:19 # 3
Demir42
[QUOTE = sonerkyl] welcome first, my teacher, have a throat butterfly cleared in your vehicle. [/ QUOTE]
Thanks for your reply, hodja. We're [I'm] glad to be here.
Could there be a problem with the transmission? We have never changed the oil until today, 5 years old car but the km is low
08.05.2020 19:19 # 4
berk2309
Is my role playing, when you stop doing this process, do I get up and get lost? Or is it just sound from the engine?
08.05.2020 19:19 # 5
Demir42
Tachometer does not rise when I look. The car is as if going into winter mode
08.05.2020 19:19 # 6
It is said that how many kilometers of vehicles, in other places, 40000 km change is necessary. Of course, it may be another problem that you have to go to the service and look through a computer.
08.05.2020 19:19 # 7
Demir42
52 thousand
08.05.2020 19:19 # 8
ismailkaya
When you start for the first time, it comes into play with automatic output. After 3 minutes, when the engine reaches certain temperature, the irregular operation that you call disappears and your vehicle gets flat.
08.05.2020 19:19 # 9
ismailkaya
If this happens when you come to the lamps while the vehicle is in motion, it works with the electrics of your car, the systems are working too much, for example, the air conditioner is on, the headlights are on, the brakes are on, the tape is on, the steering pump is constantly working, it does not cause any problems when your vehicle stops, it is okay to stop your car. you experience an impairment
08.05.2020 19:19 # 10
Demir42
[QUOTE = ismailkaya] If this is done when you come to the lamps while the vehicle is in motion, it works too much. If he has completed his life, you will experience an inevitable impairment occasionally [/ QUOTE]
Could there be a problem with the charger?
08.05.2020 19:19 # 11
sezar206
Cheapest butterfly throat cleaning do it first. B. Possibly that problem. Have spark plugs ever changed? Idling engine does not fail immediately, I think 52000 more.
08.05.2020 19:19 # 12
Demir42
[QUOTE = sezar206] Do the cheapest butterfly throat cleaning first. B. Possibly that problem. Have spark plugs ever changed? Idling engine does not fail immediately, I think 52000 more. [/ QUOTE]
Spark plugs have changed for 3 months or so, hodja
