Skidding problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
08.05.2020 21:10 # 1
mesut_k61
I bought my 308 car about two months ago, I didn't realize it at first, but when the car got off the road, it slipped off the road in a sweet way. It continues again. laser rod send to balance
The minister said that there was no problem, this situation makes me nervous, I cooled out of the vehicle officially, if you have information about how we can solve this problem, please share it.
08.05.2020 21:10 # 2
Orcun.Dmr
I know that there is no torsion in the 308s.
08.05.2020 21:10 # 3
There are 308 torsions orçun :) Of course there is a slightly different design spring. When it comes to the problem of our friend, my teacher has the control of the shock absorbers, and there is a problem with them, although the torsion bushes seem to be intact, there is internal wear. What is the production date of your tires, my teacher and brand. ? I have been using it for 1.5 years, and I have never had such a problem. In the meantime, I wish you to use your vehicle without accident and good luck. sonerkyl 2019-02-26 10:36:08
08.05.2020 21:10 # 4
mesut_k61
we have checked the history of tires now two of them in different months, two of them are produced in 2015, two of them are 2017, my problem seems to be the size of the tires 205 55 16 goodGood efficientgrip. mesut_k61 2019-02-28 11:42:00
08.05.2020 21:10 # 5
If the old-fashioned tires are at the back, the glide is probably due to them. I bought hankook ventus prime 3 last year, I used 15000 km, braking wet-dry braking distance did not upset me. michelin beautiful lasik but really too expensive. Frankly, I don't know if the price difference is worth it. There is no problem with your tire sizes, you shouldn't expect more than 4 years of tire performance. I always do good research and get foreign forums. Micheline if you want me to pay so much, do some research so the tires
https://www.adac.de/infotestrat/tests/reifen/sommerreifen/2018_sommerreifen_test_205_55_r16.aspx
sonerkyl 2019-02-28 12:09:09
08.05.2020 21:10 # 6
Orcun.Dmr
[QUOTE = sonerkyl] There are 308 torsions orçun :) of course there is a different design spring or something. When it comes to the problem of our friend, my teacher has the control of the shock absorbers, and there is a problem with them, although the torsion bushes seem to be intact, there is internal wear. What is the production date of your tires, my teacher and brand. ? I have been using it for 1.5 years, and I have never had such a problem. In the meantime, I wish you to use your vehicle without accident and good luck. [/ QUOTE]
Is there anyone who has this torsion called 307, brother?
08.05.2020 21:10 # 7
mesut_k61
friends, I solved the problem of swings, at the end, ten table bushings were torn and when the table bushings were installed, the nut screws were not fully tightened.
08.05.2020 21:10 # 8
[QUOTE = mesut_k61] friends solved the problem of swings, at the end of the table, the bushings were torn, and when the table bushings were installed, the nut screws were not fully tightened and the rear shock absorbers were replaced, and the problem has disappeared for the moment.
I'm glad your problem is solved, hodja. so what is not to tighten the front plate nuts of friends. Angry . As I said, my teacher has good handling.
08.05.2020 21:10 # 9
[QUOTE = Orçun.Dmr] [QUOTE = sonerkyl] There are 308 torsions orçun :) Of course there is a slightly different design spring. When it comes to the problem of our friend, my teacher has the control of the shock absorbers, and there is a problem with them, although the torsion bushes seem to be intact, there is internal wear. What is the production date of your tires, my teacher and brand. ? I have been using it for 1.5 years, and I have never had such a problem. In the meantime, I wish you to use your vehicle without accident and good luck. [/ QUOTE]
Sorry, your fast has a similar system that has gone unnoticed, bro. Like 308
08.05.2020 21:10 # 10
x571
[QUOTE = sonerkyl] [QUOTE = mesut_k61] friends solved the problem of the slash, at the end of the table, the bushings were torn and when the table bushings were installed, the nut screws were not fully tightened, and the problem disappeared for now. QUOTE]
We live with your honey. They did not squeeze the tie rod of a friend, but he was on the road at low speed.
