|   | Sizzling on the Radio |
| 08.05.2020 16:25 | # 1 |
|  felusdomesticus | |
|  My vehicle 307 XT. Although I am in the heart of the city in Ankara, there is a sizzle on the radio. There is no such problem with the CD player, but there is a sizzle on almost all channels as if I switched to the radio, as if I was in a place that did not shoot.   Does anyone know the cause and solution of this problem? < / div>
| 08.05.2020 16:25 | # 2 |
|  06OzGuR06 | |
First of all check your car's radio antenna. If there is a break or something & nbsp; if not, remove the antenna and check for oxidation at the bottom of the antenna. If oxidation occurs, use the rust remover spray to remove the bottom of the antenna (metal part) Replace the antenna. Try this way, if the problem persists, check the antenna input on the back of the tape. .peugeotturkey.com / forum_posts.asp? TID = 18245 & amp; title = 2005-307-non-radio-issue- | |
| 08.05.2020 16:25 | # 3 |
|  felusdomesticus | |
Thank you very much, I hope I will try this advice tomorrow morning first thing, my problem will be solved too :)
| 08.05.2020 16:25 | # 4 |
|  06OzGuR06 | |
I would be glad if you share the result here.
| 08.05.2020 16:25 | # 5 |
|  djchaos | |
we help other friends by sharing the result.
