SINGLE 206 GTI
08.05.2020 19:44 # 1
vahitender
HELLO TO EVERYONE, I ARE ARE WRONG TO THE WRONG PLACE.
CAR 2001 MODEL 206 GTI 2.0 ENGINE
WHEN I PRESS THE GAS IN THE VEHICLE, I WERE DISTRIBUTED FROM TIME 2 AND BEFORE, AND WAS CORRECTED. SHIFT AFTER TRANSFER OR GAS AZ PRESS would DO GO when misfire FINAL TOP SPEED in TOOL COMPRESSION when misfire PROBLEM TO CONE OLMUYORDU.TAMİRCİ to WENT TO DONORS WILL NOT BE SAID we SEE PART WHERE COIL REMOVE My SPARK 3 CM UP DIRTY WATER We SEES DEPOSITS OL COIL AND 4 PLUG ZERO TAKE We CHANGE ISSUE ADJUSTED of. STARTED AGAIN WITHIN 2 DAYS. As far as I have observed, water is coming from the top of the coil to the upper part of the coil and it flows from here to my eyes.
1. CAN THE WATER TROLLE BE OLD AND CORRECTED AND HOW CAN I CHANGE THIS.
2. THE PART OF THE WIPER WIPES ARE LOCATED ON THE TOP OF THE COIL HOW TO CUT WATER THERE IS ANY WATER FLOW FROM HERE.
OR HAVE ANOTHER SOLUTION?
SOMEONE LONG WAS HELP IF YOU CAN HELP YOU THANK YOU NOW ..
08.05.2020 19:44 # 2
peugeot murat
Where the coil is, there are 2 plugs can be drilled
08.05.2020 19:44 # 3
vahitender
Tomorrow I will replace the water plugs, clean and return, thank you :)
