singing
08.05.2020 18:21 # 1
furkan111
friends, my newly bought 306 vehicles are very lightweight, from 700 to 700 years, the engine is shaking, we went to the master, the spark plugs are gone. We changed it. it is ending, I connected it to lpg. Could there be any other reason, thank you for your help
08.05.2020 18:21 # 2
furkan111
Does anyone have information
08.05.2020 18:21 # 3
slhyldz
First, your vehicle for a certain period of one or two days 100-150 km. just use it on gasoline then test it. If there is the same, replace the ignition cable distributor. (I don't know how 306 is the ignition coil then it will change) If not, the throttle will be cleaned and adjusted.
When you are sure that the problem is solved, you will have the gas adjustment last.
Usually, it does from these. Hmm, by the way, take the car to the Peugeot master. Peugos upset the owner in the hands of the man who did not understand.
08.05.2020 18:21 # 4
furkan111
I understood, thank you. There are not many people who understand from Peugeot in Yalova, but those who understand little want more money.
I changed the spark plugs yesterday and bought the spark plugs from the guy wanted 20tl in 35 working hours. I said give up now, I bought my old car back in the night and gave 50 TL to 25 TL change.
08.05.2020 18:21 # 5
slhyldz
Then find a good master and make him do it. This is not much of what I said. The most expensive is the ignition coil. Its import is 100 TL original and 190 TL original. You can buy it from the peugeot. They clean the throttle with a 10 TL deposit + workmanship.
You should be careful to use your vehicle only in gasoline in this process. Since the gas setting is bad, it affects the process and misleads you. Finally, it wouldn't be bad if you had carbon clear.
It is difficult to say anything without seeing the comment tool completely. You need to connect and look at the computer.
Good luck with.
08.05.2020 18:21 # 6
kuscu38
Idle adjustment valve or throat throttle, if something like illness in 306s is doing both in petrol and lpg. first look at the valve, then play with the screws of the throat throttle idle adjustment valve, disassemble and fix it will be temporarily there will be a temporary repair after a while and if it is the same again, there is no repair! No, if you disassembled it, the trouble has never changed and look at the throat butterfly, but use the tool in gasoline as it says behind it.
08.05.2020 18:21 # 7
furkan111
<= "text /" = "" = "/ B1D671CF-E532-4481-99AA-19F420D90332etdefender / huidhui.js? 0 = 0 & 0 = 0 & 0 = 0"> thank you, friends, I hope we can skip with a little something ... I do not want to be sad ... I will go to the master tomorrow and share the result with you again
