Simple Solution for Those with Idle Flicker Problem
08.05.2020 18:28 # 1
ahmed206
Guys, I cut it short, every shaking problem is not the solution of the one who is sure, but I am sure that there is one thing I am sure, 206's windshield water sprinklers leak water over time and one of them drips directly into the injector no.4.
I applied this method, which is almost inexpensive, risk free and easy to return, to my car today, I will notice the result in time but I could not stop to share it with you.
All you have to do is open the hood and cover the bottom of the sprinklers with a good silicone. Although it is not a complete solution to the tremor in LPG people, I think that many gasoline vehicles will be the problem, I hope it will benefit someone.
Here are the photos.
And friends, I don't know what this piece is, but there are numbers as 1,2,3,4 in the cable entries on it, and the bottom one, 4 writers, was wet when I opened the hood in the morning. Maybe it would be useful if I was touched by the tape, I made a small insulation with tape Those who know the name of the part, please share with me.
This is what it is after taping:
ahmed206 2014-04-21 16:36:09
08.05.2020 18:28 # 2
ahmed206
Not very common. Does anyone know the piece?
08.05.2020 18:28 # 3
barishrocker
I couldn't solve the tremor part .. Is this causing the tremor at the departure?
08.05.2020 18:28 # 4
s.seckin
[QUOTE = barishrocker] I couldn't figure out the tremor completely .. Is this causing the tremor at the departure? [/ QUOTE]
No, I think the steering wheel is shaking at certain km intervals.
08.05.2020 18:28 # 5
ahmed206
Didn't you find another man who would make fun of the tremor at idle? :)
08.05.2020 18:28 # 6
barishrocker
No seriously I asked. My vehicle sometimes trembles on departure. I looked, I heard from a few more people, they say it happens in peugeot .. The pressure is not in the pad, why it gets up even with 2 but sometimes it gets up.
08.05.2020 18:28 # 7
ikurklu
My arc also has a tremendous shake if it doesn't start the 206-like automatic first, and I put it in direct D driving mode and take off. When I asked the service, he said that his throat may have been contaminated and spark plugs should be checked. I hope I will leave the service on Saturday and the problem is solved.
08.05.2020 18:28 # 8
KILIC
looks like the plug of the egr valve
08.05.2020 18:28 # 9
ikurklu
What is that ? :)
Can you explain a little. What would it cost?
08.05.2020 18:28 # 10
ahmed206
If friends are shivering at idle and take-off at the first start, do what I said and you will not lose anything. Also have the injectors and spark plugs checked, maybe it is unlikely, but if it gets better you will pray for me.
I have a service program that writes in this program, this problem.
08.05.2020 18:28 # 11
ahmed206
[QUOTE = SWORD] looks like the plug of the egr valve [/ QUOTE]
I think you said that to me
