simoto air filter
08.05.2020 15:40 # 1
kaderim@61
friends bought simoto air filter I did not get more than 106, I wonder if you inform what is the plus and minus of the car;
08.05.2020 15:40 # 2
metin
if you press to hear the sound, both performance and fuel increase
If you use it normally, your fuel will be lower than the original filter, because it will draw better air than the original filter.
08.05.2020 15:40 # 3
GokhaN
If you press [QUOTE = text] to hear the sound, both performance and fuel increase
Sorry I want to ask you something.
Did you ever see any fuel in your vehicle using a sports filter?
08.05.2020 15:40 # 4
kaderim@61
so it burns less. what are the pros as performance
08.05.2020 15:40 # 5
kaderim@61
So will it burn much?
08.05.2020 15:40 # 6
GokhaN
[QUOTE = my destiny @ 61] so it burns less. what are the pros as performance [/ QUOTE]
I used 106 quiksilverda 2 different brands jsv and raid hp. There will be a slight increase in performance. You will feel the momentum in the room, usually it makes a sound. There will be a minimum increase of 20-30 kr depending on the cycle you use. The more air, the more fuel Göz Kırpma I personally do not recommend air filters in vehicles. If you use it for a long time, there is not much decrease in the fuel that returns to the original even after removal. I say these based on my own experience.
08.05.2020 15:40 # 7
kaderim@61
it is tiring the engine then thank you very much for the advice i will evaluate them
08.05.2020 15:40 # 8
GokhaN
This is a picture from the boiler raid hp application in my old vehicle. This is the way you can get the best performance. I connected the sims similar to the jsv brand directly, the era will rise and fall quickly. It will burn 2 times more than this application in fuel, between 30-40 kr more. As I say this, I say the minimum level depending on the gas pressure.
08.05.2020 15:40 # 9
GokhaN
[QUOTE = my destiny @ 61] is tiring the engine then thank you very much for the advice i will evaluate them [/ QUOTE]
You're welcome. I would recommend the final muffler instead of the air filter. The room becomes swollen after a while. The most beautiful original ride Gülme
08.05.2020 15:40 # 10
kaderim@61
the simoto of this type when i get it
08.05.2020 15:40 # 11
kaderim@61
I am thinking of removing it in the speed exhaust, so it sounds so beautiful in the era, so I can not understand that I'm going to blow both the head and the police.
08.05.2020 15:40 # 12
GokhaN
[QUOTE = my destiny @ 61] the simoto of this type when I get it [/ QUOTE]
good luck you get your enthusiasm Gülme
08.05.2020 15:40 # 13
GokhaN
[QUOTE = my destiny @ 61] I am thinking of removing it in the exozy of the speed, and it came to the day so that they could not understand that I would not be able to blow the head and the cops [/ QUOTE]
If you enjoy the exhaust, there is no sound insulation in the vehicles, you will do the best inside.
08.05.2020 15:40 # 14
kaderim@61
Thank you for the information.
08.05.2020 15:40 # 15
GokhaN
You're welcome. I shared everything I knew about 106 quiksilver as much as I could.
08.05.2020 15:40 # 16
kaderim@61
Well, can I ask you, what solution did you find in the temperature indicator?
08.05.2020 15:40 # 17
GokhaN
[QUOTE = my destiny @ 61] so can I ask you what solution did you find on the temperature indicator? If you put my indicator on, what brand did you put on, respectfully [/ QUOTE]
I had researched it, none of the air-conditioned vehicles would easily overheat.
08.05.2020 15:40 # 18
kaderim@61
I do not have air conditioning in the vehicle, the problem of heat, I was so bad, I was very sad, I do not compress the engine on the 2nd day, but for now, I was not affected by the light, but my eyes are always in the light.
08.05.2020 15:40 # 19
GokhaN
[QUOTE = my destiny @ 61] there is no air condition in my vehicle, the problem of the heat I experienced, I was so bad, I was sad and sad for the second day of the day, but I do not compress the engine, but I was still under the influence of the light, so my eye is in the light, so it is only one of the sports indicators. I am waiting for your suggestions.
I don't think they will be very healthy in them. If you buy a quality brand like Swoosh and put it on a solid master, you can get close to net values. I do not guess that it will get an accurate value from cheap indicators.
08.05.2020 15:40 # 20
kaderim@61
thanks for the suggestion
Page : / 2
