signs on the indicator
08.05.2020 17:16 # 1
nuppa
Hello, my car 2004 model 206 colorline ... I just bought it.Normally, when the ignition was switched on, the airbag and the elfren lamp were on. the lamps that I could not follow were burned all of a sudden ... it was the only abs sign in my mind. As far as I know, there is no abs in this model ... I turned the ignition on and off now again only the airbag and the hand brake lamp are on. ..
08.05.2020 17:16 # 2
xMEGANx
natural. I have 2007 307. When I turn the ignition all the lights are on, the vehicle controls the entire system. If there is a fault, it leaves the light on. If there is no fault, it turns off all the lights.
08.05.2020 17:16 # 3
Burak
this is so in every vehicle, all of them are lit for control, then a couple of lights remain on when you start the vehicle or the fault lights of the problem parts remain on
08.05.2020 17:16 # 4
batuhan9292
Does the stop lamp in 206 turn on when the contact is opened?
08.05.2020 17:16 # 5
Serkan
[QUOTE = batuhan9292] Does the stop lamp come on when the ignition is switched on in 206?
08.05.2020 17:16 # 6
KenBlockJR
[QUOTE = batuhan9292] Does the stop lamp turn on when the ignition is turned on at 206? .gif "border =" 0 "alt =" C o nfused "title =" C o nfused "/>
08.05.2020 17:16 # 7
batuhan9292
my car is not lit up, all the lamps are blinking
08.05.2020 17:16 # 8
batuhan9292
Also, the temperature indicator of my vehicle starts in the mornings, for example, 1 square above in the mornings before the first run.
08.05.2020 17:16 # 9
nuppa
thank you guys ... what was interesting to me was the ABS lamp was on ... I know this vehicle has no ABS ... I wonder if any :)))
08.05.2020 17:16 # 10
Serkan
[QUOTE = Serco05] [QUOTE = batuhan9292] Does the lamp turn on when the ignition is switched on at 206? [/ QUOTE]
I have not been riding for 5 years now, I am not sure if I do not answer, I will look at it tomorrow. I looked at the stop lamp when the ignition is turned on today.
08.05.2020 17:16 # 11
batuhan9292
I have a 2007 model, but I don't burn it ... is it normal?
08.05.2020 17:16 # 12
Serkan
It does not matter if the ignition is turned on for the first time, but there may be a problem if it does not burn when it needs to be warned.
08.05.2020 17:16 # 13
ondercan
Even though abs and absence of other lamps are sometimes absent in the car :)
The solution for this malfunction is due to the bsi brain (in-car fuse box).
make it easy.
