signal problem
08.05.2020 17:18 # 1
haakaannn
Hello, when I give a signal to the left, it flashes fast and then it gets better. When I burn right signal or quadruple there is no such problem what do you think is the reason?
307 comfort 1.6 2006 lpg.
08.05.2020 17:18 # 2
Serkan
One of your left turn signal bulbs may not be on. It is probably loose, and the signal accelerates when the bulbs are not lit.
08.05.2020 17:18 # 3
haakaannn
I have repeatedly checked all the bulbs are on.
Could it be related to insurance?
08.05.2020 17:18 # 4
hhuzun
bro, check your plug in one and pass over time
08.05.2020 17:18 # 5
Aziz
You may have melted or disassemble the signal bulbs and control them. worst of all, there is a problem with the signal arm.
08.05.2020 17:18 # 6
ondercan
& Nbsp; hello
if you can remove the socket of the left tail lamp, it will be removed. let me tell you the solution.
& nbsp;
let it come easy.
08.05.2020 17:18 # 7
haakaannn
Thanks for the advice, I will see it today. & nbsp;
08.05.2020 17:18 # 8
haakaannn
I looked now, but I couldn't pull out the socket. I think it turns out to be a little difficult.
I had this problem before. & nbsp; at some point my electric pump was not getting electricity. Could it be?
08.05.2020 17:18 # 9
Bugra
There is a flasher that allows the flashing of the signals in every car, it may be malfunctioned or as the friends say, the signal bulb or the sockets there may be oxidized. Something like wd40 often gets better in the sockets or something.
08.05.2020 17:18 # 10
Aziz
Maybe in the fuse, remove the fuse of the signal, delete it, yesterday, the lights of my glass keys were blinking, I was hanging out on the automatic windows, I removed the fuses, I erased it, I fixed it.
08.05.2020 17:18 # 11
haakaannn
Thanks for the advice, I understand that I have to deal with this issue with an electrician, so there is a socket melted somewhere. Serco05 2013-01-23 09:47:28
08.05.2020 17:18 # 12
ozsimge
Slm haakaann brother
Your vehicle's problem must be caused by oxidation in the left rear stop socket.
causes it to blink fast.
08.05.2020 17:18 # 13
haakaannn
As you say thanks to all of you, my left back signal was burning in the socket of contactless contact
master bypassed with an extra cable has improved ..
