Signal Problem
08.05.2020 19:47 # 1
Poyraz61
Friends I'm using 2004 model 206 xt. During the day, when I give a signal with the vehicle, the left or right automatic headlight turns on and the signal is deactivated. What is the reason for this and is it something that can be corrected? I am playing with your right and left, nothing changes. If I turn on the headlights of the vehicle and give a signal, it is okay, but when it gives a signal during the day, sometimes it does this by turning on the headlight and cutting the signal.
thank you for your interest
08.05.2020 19:47 # 2
a situation related to sonrun com2000 my teacher may have been oxidized or you need to disassemble and look at it, but a detailed job is not something everyone can do, if you are doing this type of work you can do it yourself or do not get infected, you will get com2000 quit or you can find a figure around zero tl zero is changing around 500 TL.
https://www.araba.com/296043390-peugeot-206-sinyal-kolu-com2000
http://www.peugeotmarket.com/peugeot-206-far-kumanda-kolu-komple-orjınal,pr-895.html
08.05.2020 19:47 # 3
Cyrus35
com2000, you have to remove the headlight switch button very carefully, there is a copper integrated just below it, it had happened to me before, the headlight and the rotating little part of the park you have removed is removed. try. In the construction of the on-board computer, there is the section with the key removed,
08.05.2020 19:47 # 4
Poyraz61
Hodja what is this
I can't help it, so I don't understand much if it comes. I think it would be best to take it to the service
08.05.2020 19:47 # 5
Cyrus35
com 2000 400 tl + workmanship get to you already :)
