Signal Lever Problem
28.10.2022 16:16 # 1
bgrhngnc25
Hello.
My 307's turn signal arm does not hold, it falls to the left after signaling to the right and I have to fix it manually all the time. I asked a few places and was told that the team should change completely. Is there a more suitable and easy solution? Anyone who has experienced the same problem has solved it or has an idea for a solution. I would be glad if you help.
31.10.2022 21:46 # 2
talip206
https://forum.peugeotturkey .com/forum_posts.asp?TID=46885&title=206-com2000-signal-handle-repair
Sir, I took it apart and changed it twice. I took a detailed photo. 40 50 lira plastic piece is causing this problem.
