Signal burst
08.05.2020 17:10 # 1
eserxxx
Hello guys. I own 2003 model 2.0, 307. Right now, the right front turn signal lamp began to malfunction. Almost once a month, the lamp burst, and I was replacing the lamp. Until I realize something today. When I came home from work this evening, I realized that the signal was blinking fast, that is, the lamp burst again. I got out of the vehicle to check, looked, the signal is not lit. I said it exploded again, I hit the fender with that nerve quickly, I looked, the signal started to burn :) I think I had to change the bulbs for such a long time. So why does this malfunction occur? Come on all this time, I did not understand, it is a contactlessness that the electrician who replaced the bulb did not notice. He even said he made the rust when he last changed it, and the rust remover pushed it into the signal socket. What should I do now, if I get from Led signals, will the problem be solved?
08.05.2020 17:10 # 2
hsnsnl
Scratch the sound of the signal & nbsp; and remove the tip with the screwdriver from the bottom & nbsp; again after the experiment, or the + tip with the screwdriver and scratch the rust in the socket.
