signal bulb replacement
08.05.2020 14:54 # 1
ayter
I want to attach a double-sensed signal to the case 307 with make-up, but I need to get the headlight to the part where the signal is. Herhlde.I do not start long heat if the headlight is removed without inserting the bumper. aytar 2010-10-16 11:43:13
08.05.2020 14:54 # 2
TA3537
If it is made without cutting the space in the bumper and opening the space, I think it stays outside.
08.05.2020 14:54 # 3
ayter
Isn't there a signal shifter?
08.05.2020 14:54 # 4
muratgulen07
ayter that vehicle does not need any bicycles, look at the napnik
08.05.2020 14:54 # 5
ayter
[QUOTE = muratgulen07] ayter that vehicle does not need any bicycles look at your pleasure napıcan signaled ampoule :) [/ QUOTE] Gülme What do you think is something that is burnt in the park?
08.05.2020 14:54 # 6
Muhammet CAKIR
[QUOTE = ayter] [QUOTE = muratgulen07] ayter that vehicle does not need any bicycles look for fun napican signaled ampoule :) [/ QUOTE] Gülme What if I was tied to the ring in the parks with nothing but a ring of angels, the signal rings in the parks of my double-sided ring [/ QUOTE] do not need a double lamp to do this operation http://www.peugeotturkey.com/nasil_yap. = 16 here I think the process works
08.05.2020 14:54 # 7
ayter
[QUOTE = crazycakir_43] [QUOTE = ayter] [QUOTE = muratgulen07] ayter that vehicle does not need any bicycles look at it, napıcan signaled it is lightbulb :) [/ QUOTE] Gülme What if I was tied to the ring in the parks with nothing but a ring of angels, the signal rings in the parks of my double-sided ring [/ QUOTE] do not need a double lamp to do this operation http://www.peugeotturkey.com/nasil_yap. = 16 I think the process here will do the job [/ QUOTE] I wanted the signal in the headlights to light up, I split the old like my old car
Uploaded with ImageShack.us
08.05.2020 14:54 # 8
Muhammet CAKIR
I understand that I already gave that link or if you follow the same action in those signals, you will get the same result :) When the parks open, it will burn steadily.
08.05.2020 14:54 # 9
ayter
[/ QUOTE] tells the link of the fender signal to the parks in that link, but I misunderstood me Confused
08.05.2020 14:54 # 10
deniz_206
I think the fender signals are enough to be directly connected and I think it would be an exaggeration.
08.05.2020 14:54 # 11
Muhammet CAKIR
[QUOTE = ayter] [QUOTE = crazycakir_43]
[/ QUOTE] tells the link of the fender signal to the parks in that link, but I misunderstood me Confused [/ QUOTE] you got it right, but I say you can do the same with the front signals :) I mean if you cancel the chassis of the front snake (-) and connect the plus (+) pole received from the parks to the chassis of the signal, the signal will light up when the signal is signaled, then the signal will flash.
08.05.2020 14:54 # 12
ayter
we finally did
