Signal Begins Flashing Quickly
08.05.2020 19:28 # 1
samet206
Hello friends today, such a situation happened to me when I was cruising, my right signal is working as it should be, the left signal is working faster.Also, one of the bulbs exploded, the signal got off the front vehicle, front-side-rear, all of them are burning. When I am available.
08.05.2020 19:28 # 2
xmen
Probably the sender is malfunctioning
08.05.2020 19:28 # 3
samet206
I guess that the lamps will not light up if the sender fails because the lamps work smoothly. Only the left signal has accelerated more than necessary. There is no problem in four, there is no problem in the right signal.
08.05.2020 19:28 # 4
koray.turan
My head came to a certain point, but I have an American park and it is sourced from it.
08.05.2020 19:28 # 5
oguzhan53
Disassemble the socket of the rear stops, look inside, and you will see that the ends of the socket make an arc, clean it nicely and put it back in place, and make sure that the problem will be solved.
08.05.2020 19:28 # 6
samet206
[QUOTE = koray.turan] My edition came to a certain point, but I have an American park and it is caused by it [/ QUOTE]
I'm not using an American parking module, sir, only orange parking bulbs are normal.
08.05.2020 19:28 # 7
samet206
[QUOTE = oguzhan53] Disconnect the socket of the rear stops, look inside, you will see that the ends of the socket are arc, clean it well and put it back in place, make sure the problem will be solved.
Thanks may be as you said I will check the left stobe.
08.05.2020 19:28 # 8
Alicilik
Musur, I don't understand what matters, but there may be a problem with his roles of 4.
What about the brightness of the bulbs?
08.05.2020 19:28 # 9
samet206
The friend said so, I replied, I did not hear about a signal, and I did not say anything because I did not know clearly before. 4 is working as it should work without any problems. It works the same way on the right signal. I do not notice if you ask them to burn, it is normal for me. I will change all the signal bulbs on the left side. I don't know what happens at the time. I did not touch anything, the problem still continues.
08.05.2020 19:28 # 10
xmen
Signal puller was wrong sorry :)) signal flasher relay may have problem xmen 2015-10-14 01:00:38
08.05.2020 19:28 # 11
pekmez006
This problem is not the same thing, check the lamp directly. When the front and rear signals are removed, someone flashes fast and the same thing happened to me. Do not deal with the signal arm, look directly at the lamps.
08.05.2020 19:28 # 12
pekmez006
Give the signal, get out, do all the signal lamps (the side you give) burn out of the vehicle
08.05.2020 19:28 # 13
samet206
Thanks, master, I did not even suspect the signal arm or something, it was the first thing that came to my mind.
08.05.2020 19:28 # 14
pekmez006
2 years ago I broke the arm because of a stupid master came out of the lamp but watch out
08.05.2020 19:28 # 15
tsufrankwoli
Sir, if the lamps are intact, there is a problem in the socket. The same thing happened to me, if one of the lamps explodes then it beats fast to get attention.
08.05.2020 19:28 # 16
samet206
Thank you guys, I will change the lamps for your suggestions, check the sockets, I will check the stob in the meantime, I hope there was no other problem.
08.05.2020 19:28 # 17
samet206
Hello guys today I came to the conclusion by doing all the checks, the back signal is sometimes lit, sometimes it is interesting that the reason is not lit.First I dismantled the stobe, there was no problem in the sockets, oxidation or something, then I looked at the bulbs. If not, I still chewed, then replaced the stocks by replacing the bulbs. I tried it beautifully, thank God.
08.05.2020 19:28 # 18
My teacher provides a contact spray, it provides cleaning in this type of electrical connections.
08.05.2020 19:28 # 19
samet206
I had a wd40, I had a little left in the trunk, I cleaned it with lightly, of course, as you said, it is nice to have a product in contact spray in the hands of people for these works :)
