signal arms and airbag wrap
08.05.2020 19:50 # 1
canbulat55
Hello friends, I haven't been in the forum for a while. In the 2004 model 307 1.6 lpg automatic xt premium car, the airbag lamp has been on for the last 1-2 months and the signal handle is not working properly. the airblower light had gone out when the cables under the seat had been tampered with. probably caused by airbag wrap. If I took this airbag wrap, I installed it myself and connected it to the computer and any coding etc. I would be glad if you give me information if it should be done or I would work directly. Where can I get this piece at an affordable price? I also changed the gear solenoid valves and oil about 6 months ago in my automatic gear car. Until recently, there was no problem, but recently when I pressed the brake, it seems like the gear has been in position despite being in position d, and when I hit the throttle for starting, it hits at the same time. It can happen when I throw from N to D, and when I throw from N to R, it usually hits as a plug. In my research on plug and shump sounds, it is mentioned that it may be from the brake sender. I bought the brake sender today.
