Signal arm problem
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:28 # 1
syz33
I have the 2003 model 307 and I have the classic signal arm problem too. It stands loose, sometimes gives a signal that is not worth it, sometimes it is difficult to move sometimes while turning the steering wheel. My guess is that there is a bruise or something on the nails. There were a few sample videos here, but I want to take a hand out and deal with it someday. I am calling and waiting for your health from here.
08.05.2020 18:28 # 2
newlook45
I have the same problem with me, I give a signal to the left, sometimes I am giving it to me when I go straight.
08.05.2020 18:28 # 3
barishrocker
I always make a selector while giving a signal. I wonder if mine started to deteriorate too ..
08.05.2020 18:28 # 4
ahmed206
There was a similar problem and solution in the forum. I remember his video. They were squeezing scotch brite dish swag at the bottom. Even if you don't put scotch, scotch is a bit expensive :)
08.05.2020 18:28 # 5
syz33
Yes, there is such a video, but I am looking for a solution by repairing it. If there is information picture about such a subject from our masters, I expect a solution from them. On Wednesday, I will share the picture if the holiday goes hand in hand. I am tired of this kind of classic problems of the piano and there is a rain sensor while working sometimes it is in the middle of the window.
08.05.2020 18:28 # 6
[QUOTE = syz33] Yes, there is such a video but I am looking for a solution by repairing it. If there is information picture about such a subject from our masters, I expect a solution from them. On Wednesday, I will share the picture if the holiday goes hand in hand. I am tired of this kind of classic problems of the piano, and there is a rain sensor while working sometimes it is in the middle of the glass.
I would recommend you to buy a new one for the past 90 TL I bought it (for 106) 3 months ago, it costs 40-50 TL.
dogan106 2014-04-20 23:07:15
08.05.2020 18:28 # 7
syz33
I guess the 307's signal arm is not so cheap, but the more expensive 500 with rain and headlight sensor modules.
08.05.2020 18:28 # 8
ilyas
I had a similar problem in my 2003 model 206, I am sick and tired of it. When I changed it, I realized that the arm I bought was not from the 2006 model, there was nothing in the 2003 model, but they made an apparatus in 2006 and it doesn't fall easily. Climbing around 500-600 TL can be found as zero and 150-200 TL. As a practical solution in the forum, if you searched for sponge under the signal arm, you can find it.
08.05.2020 18:28 # 9
tilbe307
friends I have an unpleasant experience on the same subject. First of all I said let's tighten loose in my signal. I went to industry, opened a master, but broke the arm while doing. now it's broken and I need to change it now. In other words, if you have a master who understands it very well or if you understand it, if you do not have an effort, a cost of 300 can wait for you. Good luck with
08.05.2020 18:28 # 10
murat222
friends signal arms inner mechanism is simple try to clean inside my problem was solved so
