signal and horn
08.05.2020 20:41 # 1
hulya1558
I'm giving friends signal for 2 seconds, clicks, then goes off and goes off the headlights when I give a signal is this normal? light right-handed dock and do not click again, it closes again, it goes on its own dashboard immediately
sometimes it should not be played by touching the signal on the horn. how much is the average?
08.05.2020 20:41 # 2
husem
Your vehicle is 206 I think. There shouldn't be a lane change function in the 206's, at least I don't.
When the lane change function touches the signal lever lightly, the signal turns on and goes off 2-3 times so that you change lanes over time.
You raise or lower it completely, right?
It is not normal for the headlights and signal to go out. The headlamp signal arm may be defective or com2000.
08.05.2020 20:41 # 3
hulya1558
Yes 206.Is also changing lane but it turns off immediately when normal turn signal
08.05.2020 20:41 # 4
hulya1558
and when you touch the signal, the headlights go, then the headlights turn on again, the signal immediately
atio after 2 clicks
08.05.2020 20:41 # 5
husem
Arm is probably broken
08.05.2020 20:41 # 6
hulya1558
Is it too expensive arm
08.05.2020 20:41 # 7
hulya1558
the handle for the tape recorder on the right hand side of the steering wheel is also not working.
08.05.2020 20:41 # 8
hulya1558
I would also like to have a modified Istanbul k.çekmece or is there a place that makes it beautiful?
08.05.2020 20:41 # 9
husem
If it is com2000 yes it would be better if an electrician / electronics engineer looks The radio control only works on the original tape.
08.05.2020 20:41 # 10
husem
[QUOTE = hulya1558] I would also like to make a modification Is there a place that makes Istanbul beautiful in k.çekmece or its immediate surroundings? [/ QUOTE]
Friends from Istanbul will respond.
08.05.2020 20:41 # 11
hulya1558
thank you so much thanks
08.05.2020 20:41 # 12
peugeotefe
Your signal arm is defective. There is a short circuit where you turn on the headlight. The signal arm needs to be changed. Repair is possible.
08.05.2020 20:41 # 13
kayaca
I had a problem in the signal arm, did I give a signal to the left or to the right? It was cut after 2 clicks. For example, I was hurting the fog. calısıyor
08.05.2020 20:41 # 14
hulya1558
[QUOTE = peugeotefe] Your signal arm is defective where you turn on the headlight, there is a short circuit. The signal arm needs to be replaced, repair is possible.
Is this the price you said is the price of the original arm?
08.05.2020 20:41 # 15
maximusti
[QUOTE = hulya1558] the handle for the tape on the right side of the steering wheel does not work, can we change the tape or do we have it [/ QUOTE]
1.The problem signal arm (com2000) is faulty, there are alternative correction methods but it needs to be changed to be healthy.
steering wheel control also does not work because the tape has changed, it has an apparatus of 100 150 tl for it to work, it must be installed, (not all models support tape)
08.05.2020 20:41 # 16
ggitaristt
[QUOTE = rock] I had a problem in the signal arm, did I give a signal to the left or signal to the right? It was interrupted after 2 clicks. For example, I was hurting the fog. coming fast sometimes not working properly [/ QUOTE]
fast click click click mine would sometimes do sometimes it would not do .. My problem came out in the left rear stop socket .. The chassis was weakened because the socket was melted .. I cleaned it, I fixed it.
I think you need to overhaul the front sockets and bulbs.
08.05.2020 20:41 # 17
talip206
[QUOTE = hulya1558] [QUOTE = peugeotefe] Your signal arm is defective where you turn on the headlight, there is a short circuit, the signal arm needs to be changed, repair is possible, it is 200 TL price including disassembly and fixing parts [/ QUOTE]
Classic com2000 failure. In 206, the headlight signal wiper arm and airbag coil are at the same center. Often a common malfunction. If you buy the original price range from 800 to 900 TL. Its repair starts from 150 TL depending on the situation. If you find a good electrician, he can fix it. I went around a few said that we can't do most One of them even got 206, how many times I had it repaired again, it gives malfunction once again every two months. So if you have it repaired, ask for at least one year warranty.
08.05.2020 20:41 # 18
peugeotefe
We disassemble your com2000, we change the signal and headlight opening arm with the original exit, your problem is solved
08.05.2020 20:41 # 19
peugeotefe
[QUOTE = talip206] [QUOTE = hulya1558] [QUOTE = peugeotefe] Your signal arm is defective where you turn on the headlamp, there is a short circuit.
Classic com2000 failure. In 206, the headlight signal wiper arm and airbag coil are at the same center. Often a common malfunction. If you buy the original price range from 800 to 900 TL. Its repair starts from 150 TL depending on the situation. If you find a good electrician, he can fix it. I went around a few said that we can't do most One of them even got 206, how many times I had it repaired again, it gives malfunction once again every two months. So if you have it repaired, ask for at least one year warranty. [/ QUOTE]
The action that most electricians will do is to solder the broken film of the Airbag winding on the signal arm, and it can be completely soldered by the soldering of the worn film of the signal arm. a modification on it is not strong enough
08.05.2020 20:41 # 20
kayaca
[QUOTE = ggitaristt] [QUOTE = rock] I had trouble with the signal arm, I signaled to the left, or did I signal to the right, after 2 clicks, it was interrupted. For example, I was hurting the fog. like click sound click sound sometimes does not work properly [/ QUOTE]
I have a parking module, they say from him, some of them are removing the parking module, it is not a problem. It seems a bit silly when I connect the vehicle and the malfunction lamp lights up.
Page : / 2
