Signal
08.05.2020 15:47 # 1
Friends, it's okay when we signal right, but when we signal left, it blinks very quickly. It almost flashes twice the right signal. I wonder why? Is there a flasher in our vehicles?
08.05.2020 15:47 # 2
metin
of course not. he adjusts the flashing and speed of the signal. But there is one I know, so I think it will not be separate for right and left for separate. Maybe there is a problem in the circuit inside the flasher, you can change the current and get rid of it.
08.05.2020 15:47 # 3
eren8er
Have you checked the fender front and rear signal from the outside? Are they flashing all? If one of them is not burning, so it flashes fast.
08.05.2020 15:47 # 4
metin
[QUOTE = eren8er] Have you checked the fender front and rear signal from the outside? Are they flashing all? If one of them is not burning, so it flashes fast. [/ QUOTE]
sensible. The current may be accelerating because it is not lit.
08.05.2020 15:47 # 5
I did not, but let me see as soon as possible. Then I got the flasher checked, I scared that it would cost us com2000 now. Thanks.
the cover 2011-07-07 13:58:38
08.05.2020 15:47 # 6
[QUOTE = kapagan] Guys, it's okay when we signal right, but when we signal left, it blinks very fast. It almost flashes twice the right signal. I wonder why? Is there a flasher in our vehicles? [/ QUOTE]
Check your left signals. One of the signal bulbs in the headlamp, fender or rear stop may have exploded. If there is no break, one of the signal bulbs is doing chassis.
08.05.2020 15:47 # 7
Absolutely correct diagnosis ... Alkış
08.05.2020 15:47 # 8
goktug
Even if the signal bulbs are loose, be aware that it does the same ...
08.05.2020 15:47 # 9
berk2309
if one of the bulbs burst, it does that
08.05.2020 15:47 # 10
cerci07
If the signal does not work, find the signal that is not lit Check the bulb if it breaks, replace it, if there is no contact, it clears and clears when plugged in again.
08.05.2020 15:47 # 11
metin
I learned something new :)
08.05.2020 15:47 # 12
The left front signal was making contact in the headlight. We cleaned it and put it back. Fixed. It was just like you said.
08.05.2020 15:47 # 13
dude the bulb burst out
respects
