Should the flywheel change when changing the clutch pad?
08.05.2020 19:45 # 1
conywolker
Hello everyone,
I joined you as of Monday. I bought a 2005 model 307 xt premium. 1.6 110hp manual gearbox.
I will change clutch lining and timing circulation etc. However, in a few places, while the clutch lining is changing, I read that the 110bg models should also change the volant, etc. As you know, volant alone is quite expensive.
Does the flywheel have to change, will I have trouble if I don't?
I also expect a special service proposal in Ankara. How much are these transactions estimated?
Thanks for your answers ...
Note: My vehicle is Gasoline.
conywolk is 2016-04-20 10:47:41
08.05.2020 19:45 # 2
We wish you to use your vehicle without accident and good luck. I did not hear the flywheel problem for the 307s, obviously, this problem is more common in 308-407 1.6 hdi engines. If there is no sound in your vehicle when the vibration shift shifts stop, I think I recommend you to review this topic. By the way, as far as I know, this problem is only encountered in diesel models.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=18544&title=ankara-ozel-servis-tavsi to
08.05.2020 19:45 # 3
samet206
My vehicle is not 307, but I had problems before that, because these time-consuming workmanship and the part are expensive, they cannot be dispatched immediately. I will not get into any details after tremors like the pickup truck on departures. I have grinded elsewhere.
