SHOULD THE 307 LPG ELECTRICITY BE TAKEN FROM THE CONTACT SWITCH?
08.05.2020 14:57 # 1
dikmentr
FRIENDS HAVE BEEN BUILT FOR 1 MONTH BAKIR MIXING AND RICH MIXING ERROR I WON'T CORRECT
SIRF UGRAŞITIGIM EXPENSES SPARK PLUG THROTTLE CC CLEANING OIL GENERAL MAINTENANCE THIS MONTH
THE OXYGEN SENSOR THAT THEY WANT TO GO TO MY GASTER FOR 2 WEEKS MAY BE DEFECTIVE, BUT WHEN I LEAVE FROM LPG 10KM CARE, THAT GAVE THIS ERROR
I WENT TO THE ORIGINAL ROMAN'S OWN SERVICE, THE MASTER WAS NOT A SETTING CASE, IT HAS BEEN RICHING THE UPGRADE SETTING THIS TIME WAS RICH TO CONTINUE TO THE NORMALE CONTACT KEY IN THE MASTER WHEN I HAVE CLOSED THE CONTACT KEY, I HAVE THE KEY CONTROLLED THE KEY, I HAVE GOT THE KEY TO THE CONTACT KEY.
AND INCORRECT ASSEMBLY DEDU THIS electricity COIL injector BRAIN LIKE GROUND ALMIŞŞS to LIABLE FOR DOING LIKELY SAID MOST DIRECT CONTACTS SWITCH from Alican DEDU TAKTIRGI did PLACE TO GET A EDIT they DEDU when SAYGILAR from OBTAINING from SİZCE IGNITION .. lesion improved THUS something right my BECAUSE THIS MASTERS Canımı seven are SIRF DEALING to the IC's GUN TO SOMEONE ELSE THROWS ARE WAITING FOR YOUR AIDS
dikment is 2010-11-13 13:50:10
08.05.2020 14:57 # 2
Onur
I do not know if it is pulled out of the coil, I do not know if it will be a problem, but I do not know how to get it from the contact.
