should i have lpg
08.05.2020 17:58 # 1
bysarsinti
slm guys nowadays everyone around me started getting lpg. My vehicle is a 2001 model 206 XT 1.6 engine. 110 hp at 160 000 km. I made 335 km for 100 TL last night.
1- How much will I drop if I put a tube?
2- How much performance of the vehicle decreases.
3- Is there a need to charge
thank you in advance for your thoughts ...
08.05.2020 17:58 # 2
impact
It's not bad, but if you get LPG, I think it will be 25-26 cents.
08.05.2020 17:58 # 3
Serkan
You won't feel the performance, my teacher saves around 35-40%, if a good assembly and kit are not installed, it can burn the car :)
Edit: It can burn metaphorically, because of the problems, let me burn and let it burn :)
Serkan 2013-09-30 15:42:02
08.05.2020 17:58 # 4
bysarsinti
If my impact teacher drops 25-26 cents, if I install a tube for 1500 TL, he pays for himself at 37500 km. then there is no need.
When I got out to overtake a car Serkan teacher when it comes to performance tube 5. If you require me to drop my gear 4th gear ztn it means I'm burns. A vehicle will die, I can't tire my arm :) Did I press it, it should jump to the gas without noticing 3-4-5 gears.
08.05.2020 17:58 # 5
msertkol
You won't lose performance. I advise.
08.05.2020 17:58 # 6
babatolia
I got my car 2007 307 sw, 10 days ago atiker microkit lpg, and then I went on holiday, I filled the tank on the way and when I arrived I reloaded from the same place. I bought a total of 1750km of road 330tl fuel. in Ankara from 2.38 to 76tl opium from 2.63 to 110 tl, in milas from 2.58 to 80tl in the sea, 2.50 "from the remaining tl lpg. my speed was 100 average
08.05.2020 17:58 # 7
kuscu38
I think there is no need, in today's conditions, 100 lira is 335 km, which corresponds to 30 cents, I think there is no need.
08.05.2020 17:58 # 8
omer_tarsus
If you will sell the lpg money at a maximum of 20.000 km and add 1000 TL to the value of the car. Even if you sell it after 10,000 km, it saves
08.05.2020 17:58 # 9
EmSul
I tried the fuel last week, I made 575km of my vehicle with 100tl of LPG, 320km of this is between Bursa and Balıkesir, the rest is in the city ... I was surprised by this fuel consumption. 700km more than 1 light is on, let's see.
08.05.2020 17:58 # 10
Mustafa-almanya
[QUOTE = bysarsült] If my impact teacher drops to 25-26 cents, if I put a tube for 1500 TL, he amortizes himself at 37500 km. then there is no need.
If you are doing 37500 kilometers in a very short time, it may still be worth it.
08.05.2020 17:58 # 11
Mesut48
I say no thinking, I got on the gas for a long time but I said I wish I had it all over again :) If you can come to Izmir, I can recommend it to you master.
08.05.2020 17:58 # 12
EmreOz
Don't think of the high at least ... there is no performance loss, there are very few ramps, the room affects the passenger warsa ...
08.05.2020 17:58 # 13
enes_468
I am amazed at those who say that they wear lpg, they either have a lot of money or have never got into a lpg vehicle in their lives.
08.05.2020 17:58 # 14
samet206
If the vehicle is 1.6, it makes sense to install it, but if it is 1.4, I would recommend using it with gasoline. Unfortunately, 1.6 and above lpg is not drawn in today's conditions.
08.05.2020 17:58 # 15
kuscu38
[QUOTE = enes_468] I am amazed at those who say they are not having LPG, either they have a lot of money or have never gotten an LPG vehicle in their lives. [/ QUOTE]
Why is that? I got on, but my car was running 70 cents, I wouldn't use it if it was 30 ~ 35 cents per km, I also wrote both gasoline and queue, and gas, both of them ...
08.05.2020 17:58 # 16
Burak
Depending on whether you are using the vehicle, it can be considered and inspected and I think that as someone who travels 2000 km per month.
08.05.2020 17:58 # 17
kuscu38
[QUOTE = Burak] Depending on your vehicle use, I think it can be considered and inspected.
When you run out of gas, I will buy you 5 lira :)
08.05.2020 17:58 # 18
D.EAGLE
I have 1.4, but I think I should have it. What is the best tube brand for peugeot? D.EAGL to 2014-05-10 15:13:49
08.05.2020 17:58 # 19
Serkan
[QUOTE = D.EAGLE] I have 1.4, but I am thinking about having it, what is the best tube brand for peugeot? [/ QUOTE]
There are those who are satisfied with the atiker, there are those who are not satisfied, there are those who are satisfied with the mind, there are those who are satisfied with the lovato, but most importantly, if you wear it in a place that has a good workmanship, assembly style, and refinement, you will not have any problems.
08.05.2020 17:58 # 20
D.EAGLE
[QUOTE = Serkan] [QUOTE = D.EAGLE] I have 1.4, but I am thinking about having the best tube brand for peugeot? [/ QUOTE]
You are right, teacher Wink
Page : / 2
