Should I buy stromboli rim 15 or 16?
08.05.2020 18:56 # 1
emresensoy307
My friends car 2006 1.4 16 valve 90 hp 307 original rim 15 inc I should buy 15 or 16 or whichever befitting 15 I will use the tires on the top bit, my car is the red sit site or I was wondering if I could not find the vehicle that installed this rim.
08.05.2020 18:56 # 2
emresensoy307
guncel
08.05.2020 18:56 # 3
samet206
The 15 Wheels look small in 307, but if you don't want to cut your accounts, you can buy 15 if you don't want the tire cost. If you think my car has a spring, 16 wheels will be more elegant.
08.05.2020 18:56 # 4
emresensoy307
In fact, my intention was 16 rims, but I did not find it expensive when I found it.
08.05.2020 18:56 # 5
samet206
Sir, I already know that the stromboli rim is 17 as a peugeot.15 stromboli rim, I do not know that the rim you mentioned is going to replica 15 rim 206 or so, but because the 307 is more bulky, 15 rim seems small to me or it will not be too small on 307. This is my opinion after all. I will show you if I find an example, but if you can not find it, look at you for a little look. I put 14 steel wheels on my 206, especially I tried to wear the lightest most beautiful model in the summer, I did not understand anything, but now I switched to winter tires with a hair rim, the traction increased noticeably even with snow tires, as a result the steel wheel is weighing unfortunately.
samet206 2014-12-17 03:19:19
Peugeot Forums - Peugeot Fan Club © 2025
