Shock absorber shortage (207 Peugeot)
08.05.2020 21:20 # 1
skystar316
Greetings, friends, there has been a little sound coming back from the right shock absorber for 1-2 months. I took a photo of it from the outside, as if I was lying on the side, which I thought was troubled. Do you look at the photos?
(It is displayed when the file is downloaded at the bottom)
Thank you. Best regards.
08.05.2020 21:20 # 2
First of all, welcome to us. As it turns out, my teacher, as if the top nuts were loosened. my advice is to replace the shock absorber upper bearing and chocks and make a nice adjustment. If shock absorbers are in trouble, I recommend monreo.
27.11.2020 13:20 # 3
skystar316
Thank you so much. I came across a bad master for the shock absorber and while changing it, the axle was dislocated, I think a lot of oil flowed (I guess transmission oil, I'm not very experienced, sorry :)). And he said that the shock absorber was broken, you went well that way, and said, let's replace 2 of them. I know it is recommended to change 2 of them, but I told the master to change one because I couldn't warm up. It's done. I have a question about this issue: They bought 2 liters of transmission oil and he could not change it, he took it to the next shop and said that he changed it there. (it was emptied from the bottom first) My problem is this: I guess the gear shifts were worse than before after the change. It seems like it is hard to go to 1. It was beating better with unchanged oil. I think about whether they went to the next shop and changed it. What should I do? Should I change the gearbox oil again in front of my eyes to another master so that there is no doubt in me? Or is there a measurement of this work as in engine oil? It's been a long time, sorry. Health master for your labor. Best regards ... 2009 model 1.4 hdi 207 at 205000 km.
