Shock absorber pad or dust |
| 08.05.2020 15:07 | # 1 |
these plastics need to stay inside the metal part above, right? Also, what will I do if this is harmful to the vehicle? S Ten questions I said I'd replace this plastic, but the particle said you have to replace it with this single unsold shock absorber, how true? Thank you all for your help in advance .... Have a nice day. |
| 08.05.2020 15:07 | # 2 |
metin |
What good silicone you used to fix upwards, I will fix it. The friends who already have 307 but the rear chocks are either compressing the chock or replacing the shock absorbers. I think it would be stronger if I pressed it up and siliconized, otherwise it would be more solid if I put it in some way frankly, I don't trust silicone so much, I think the shock absorber won't leave him alone there.
| 08.05.2020 15:07 | # 3 |
xdesign |
I have a similar situation on my 206. I am waiting for your solutions ...
| 08.05.2020 15:07 | # 4 |
I did not look for the Slikon brand, but if I do not try it, I will wrap it around the plastic part beautifully with an insulating tape and place it tightly.
| 08.05.2020 15:07 | # 5 |
metin |
[QUOTE = nteker] I did not look at the Slikon brand, but if I try, I will wrap it around the plastic part nicely with an insulating tape and place it tightly. [/ QUOTE] I call the master and ask him, he says, you should buy a new shock absorber. at least I'll try my luck by siliconing over the weekend.
| 08.05.2020 15:07 | # 6 |
80 pounds original and not the price of one?
| 08.05.2020 15:07 | # 7 |
[QUOTE = nteker] 80 lira original and not the price of one? [/ QUOTE] Yes, its only price ..
