Shock Absorber Malfunctions and Symptoms
08.05.2020 13:59 # 1
Drivers should be able to drive their vehicles over time
uses it by adapting to loss of grip. In general, the vehicle with bad shock absorbers
they don't realize that they use it. With sudden braking, the front of the car is as usual
If it stacks more forward and is affected by side winds, there is a problem with the shock absorbers .
Poor shock absorbers increase wear on the vehicle's coil, steering box, shaft crossmember, differential, tires, rubber bushings, gearbox, axle balls, suspension, and rod .
Loose damper connections make sound.
Symptoms of Broken Shock Absorber on Automobile
Steering wheel becomes stiff.
Pansiyon The suspension softens.
Traction weakens.
. Glides on wet ground.
steering wheel vibrates.
There is a negativity in the night vision .
Tires are worn.
 It makes it difficult to use.
Brakes are weak.
08.05.2020 13:59 # 2
sinan-s
Thanks for sharing ..
08.05.2020 13:59 # 3
Thanks Melihcim .... what do you have to do with night vision?
08.05.2020 13:59 # 4
brother due to shocks
08.05.2020 13:59 # 5
iLLeGaL
thanks for sharing melih ...
08.05.2020 13:59 # 6
[QUOTE = MELİH] brother due to shocks [/ QUOTE]
You are big :)
08.05.2020 13:59 # 7
[QUOTE = gs5165] [QUOTE = MELIH] brother because of shaking [/ QUOTE]
You are big :)
estafurullah brother embarrassed
08.05.2020 13:59 # 8
[QUOTE = gs5165] Thanks Melihcim .... what does it have to do with night vision?) [/ QUOTE]
Try it, see yahuuuu !! Thank you Melihcim Allah not let the landing gear LOLLOL
08.05.2020 13:59 # 9
thanks for sharing
08.05.2020 13:59 # 10
<bugra>
You are big :)
Big 20smil% to
especially useful for peugeot users, thanks ...
2008-12-14 00:22:36
08.05.2020 13:59 # 11
[QUOTE = 205 GTI] [QUOTE = gs5165] Thanks Melihcim .... what does it have to do with night vision?) [/ QUOTE]
We said, "What is it?"
08.05.2020 13:59 # 12
because of his health information
08.05.2020 13:59 # 13
CIHANGIR_DONMEZ
Half of the night, I can not see my head, but my head is gusel, only one night, I do not understand, I do not understand, the rot balances, the rot is broken, the tire hangs, the brakes are weak, I do not understand, the amortusor breaks out the vehicle, hissing comes sandal, it is shaking on the road, it makes a little bit, I do a little bit, I do a little bit, I do a little bit, I do a bit, I do a little bit, I do a little bit, I do a little move
