Shock Absorber Chock Problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper
08.05.2020 19:19 # 1
Shamil
2012 model bipper family My father is driving the vehicle at 18000 km, he said that there are occasional faults coming from the front of the vehicle. Now they said to the special service fiat service that the front two shock absorber wedges of the vehicle were defective and they could change two for 190 TL, the vehicle was always used in the city and in particular, it was a bit strange to land these wedges in 18000, in order to find out the exact reason for this. If we want to travel 400 km and go to Erzurum service.
08.05.2020 19:19 # 2
riderzist
Check which sound is coming from, change the sound coming side. If the shock absorber block is defective, it makes sound in every hole and on the rough road. the way you use it and the way you use it is important.
You may have entered a hard hole. For the replacement of about 50 TL, the shock absorber must be removed. He has to leave the bow with pressure.
08.05.2020 19:19 # 3
Shamil
Thanks for your reply, the vehicle's shock absorber replacement was made in Erzincan special fiat service, as I wrote before, it cost 190 TL, the front two wedges landed, both of them changed, as you say, road conditions, entering and exiting rainwater deposits, rusting and wedging. In the meantime, the Erzurum Peugeot service gave a price of 325 TL for the repair.
08.05.2020 19:19 # 4
berk2309
My teacher is originally used by the private service, be sure of this, and also the original service work takes more than an hour, and how much it will work out. If you are going to have a hard night in 18 thousand, it is not possible to get out of the cracks due to your use.
