shivering on the ramp after solenoid valve replacement
08.05.2020 19:14 # 1
ugur hoca
Hi guys first. With the suggestion of a friend, I found this site and signed up immediately. I have a very annoying problem, I am waiting for your help.
I have a 2006 model new chassis 307 sw. After known automatic gear problems, I took the vehicle to the master and solenoid valves changed. however, the problems I experienced increased as they would end. My car, which does not cause problems after passing 110 km or 3000 cycles on the straight road, does not start shaking like crazy and does not eat gas if it saw a little long ramp.
it is so shaking that the car is already forced to pull the foot from the gas or something and set it aside.
At low speeds, occasionally hard and sometimes soft vibrations felt from the accelerator pedal continue.
On a straight road, if I drive at 120+ km for 5 minutes, it still does not vibrate and eat gas.
As a matter of fact, I think the event is not caused by the ramp, but from the high speed, but I cannot figure out why.
a master said that other parts may need to be replaced with the solenoid valve.
I have a wedding one month later and I will go on a long journey for honeymoon. I'm waiting for your help, ideas. thanks in advance.
08.05.2020 19:14 # 2
talip206
I don't think the event is about the gearbox. May be related to the ignition system
08.05.2020 19:14 # 3
msertkol
I think so. I say replace your spark plugs. Also, how many kilometers is the vehicle? Is there LPG? Obstruction in the LPG filter can also cause vibration.
08.05.2020 19:14 # 4
sezar206
If it is a spark plug, it does it all the time.
08.05.2020 19:14 # 5
talip206
[QUOTE = sezar206] If it is a spark plug, it does it all the time. [/ QUOTE]
I do not think so. One of our friend's spark plugs came out. He was only having trouble at a certain speed or cycle. No problems at low revs
08.05.2020 19:14 # 6
ugur hoca
Vehicle 125k friends. LPG maintenance time has passed. Also, the car does not eat gas after it starts shaking. trembling decreases when he takes his foot from the gas. When it gases, the vehicle trembles very strongly and does not eat gas. Thanks to the friends who answered. I'm waiting for the weekend. I'll show it to a master about what you say. I hope it is not from the gearbox.
